04 MAXIMA STUCK IN 5th gear and wont get out
Hey so a mechanic told me it was the transmission and wont fix with any sensor the only codes i have is for a mass airflow sensor so it jerks and cant go above 57 even in manual
There is a Blue Relay in the pass side kick panel. Its unlisted from what I can tell. Tell Him to check into this there. Verify the relay is Good. You can also jump pins to verify. There is not a lot of info on this, but it supplies power to tcm. Its a tricky diag, but I have found two this way. Back then I actually got the relay at a PNP.
Quick update
So turns out i have vvs code since it dont work at all also the whole mass airflow sensor too i took it out and its really dirty i also have a dirty cai tubes i dont know if thats what causing it from shifting.
BrandonG
Jul 26, 2019 03:35 PM
Jeremy Weitzeil
Sep 22, 2018 10:58 PM
Gary05Max
Jun 9, 2018 04:30 PM
