Synthetic or conventional oil?
Old Apr 16, 2025 | 04:24 PM
sp600jx21a's Avatar
I have a 2004 MaximaSL. I have always used conventional motor oil. Since this type is getting harder t find. My question is should I go with synthetic? I know for a fact when our fleet went with synthetic new oil leaks have appeared. Will I also have the same thing happen to mine? The Maxima runs just fine and not looking to jinx myself.
Old Apr 17, 2025 | 08:17 AM
slvr2KSE5's Avatar
Youll be fine. these cars only have 4 common leak points (upper oil pan seals, both valve covers, and oil cooler o-ring) none of which switching to synthetic would have an affect on. these parts leak simply due to age and hardening of the seals.
Old Apr 17, 2025 | 03:12 PM
Les7311's Avatar
Already sold that car….but
Used synthetic blend for years….. then one crazy weekend decided to use the leftover conventional then switch back later ( you reversing my process ).
By end of day the rear main seals started leaking oil bad….. shop said $3k fix. Locale store stop leak resolved was about $15
go fish….
Old Apr 18, 2025 | 08:24 AM
slvr2KSE5's Avatar
in 25 years of being in a shop ive never heard of transmission join up seals. you have a rear main seal (that almost never leaks on a VQ) and the upper oil pan end seals (that get hard and crack. always assumed to be a rear main leak)
Old Apr 18, 2025 | 06:16 PM
Les7311's Avatar
rear main seal. Thanks for your 25 years+
Old Apr 19, 2025 | 07:20 AM
Craig Riker's Avatar
I also got tired of searching around for my favorite brand and weight oil and filters so I order it from Amazon. Screw the brick and mortor stores if they want to play games! In case you're wondering I like Valvoline oil and WIX filters.
sp600jx21a
Apr 16, 2025 03:30 PM
succamadeek
Sep 26, 2006 07:19 PM
MAXRN
Fluids and Lubricants
Sep 14, 2005 02:00 AM
rcy
Feb 12, 2004 01:35 PM
