Oil Filter Access
Oil Filter Access
I am in the middle of changing the oil on my '09 Maxima for the first time. Access to the oil filter from the bottom is blocked by a plastic shroud. I can see that this shroud is held in with plastic poppet fasteners. But I don't know which poppets to pop.
It also seem possible to access the filter by removing the right front wheel.
What is the easiest method to get at the filter?
CT Maxima,
There is a thread below about Maxima specific oil where someone discussed the cover. Bleow is a copy of that post. Hope this helps.
Hello everyone. I spoke with someone at Baker Jackson Nissan here in Houston and asked about the oil. He said that they don't carry the oil (with the additive) and that any good 5W-30 oil would be fine. He did mention Castrol GTX.
Also, I changed my oil today for the first time and there is a strap holding a plastic cover over the oil filter. There's a plastic push-pin that you have to remove in order to remove the strap and access the filter. I just used a flat-head screwdriver to pop the center part out so that the strap could be removed. Just letting the rest of you DIYs know just in case. :-)
I did a search on oil filter and "oil filter" and could not find the referenced thread.
Let's see if I can pop it off.
Those plastic fastners can be tricky. I like to use a thin flathead screwdriver to 'pop' the center rivet up. Then the whole fastner can be removed by pulling gently on it. It's gotta be easier on the Max than the 350Z- I have to remove 12 10mm bolts and three fastners to drop the plastic engine pan before changing the oil on the FM chassis.
Sorry to hear that! I used the smallest screwdriver I could find and just popped the center part of it out. I must admit that it took me a little while to even locate the filter. I just assumed that it was in the exact same spot as on my 1998 Maxima. I guess technically it is...Nissan just added do-it-yourself-deterrent shrouds around it.
When you remove the poppet holding the strap, it allows the shroud, which is flexible, to be moved. Even so, you do not have clear access to the filter. Imagine the filter is a fetus in childbirth and you will know what I am talking about.
Here is a strange event observed during the oil change. As I was pouring in the fresh oil, its travel down the engine induced a resonance frequency sound. It was very similar to the sound crystal stemware makes when rubbed a certain way. For those who do their own oil change, listen for the sound next time.
Changed my oil too for the first time this weekend. I used my 3 ton floor jack to lift her up, there is a good spot right down the center of the car under the engine. It is not very pronounced like my 95 was, but you should be able to see it.
The shroud was no problem, I poped a few extra fasteners to see if it makes it easier to access the filter. It was not, so from now on I will just undo the one under the strap on the bottom of the car. I wedged a piece of cardboard to keep plastic from getting in the way, worked out well.
What was a PITA though is that filter is recessed so deep in the car, when you take it off, the oil runs all over the place. While trying to mop up in there, I cut up my fingers pretty good on sharp metal edges. So be careful or wear gloves if you go in there.
I wish there was a trick to capture the oil from the filter somehow.
On the plus side, to remove the filter I used a plastic cup end filter wrench that I got at walmart. Worked great! On my other car I have to use slip over wrench, which is a pain.
I also installed a Fumoto Oil valve, which should make future oil changes go smoother.
I tried taking pics, but they did not come out too well. Did not hear any weird noises while pouring oil either, but I did not pay much attention to them.
Holler if you need help.
Max
Max
If the engine blows and/or seizes and it is directly linked to you not tightening the drain plug enough or oil filter enough and causing the oil to leak out then yes.
Does anyone know if the poppet that you have to remove to access the filter is the same size as the one holding the left side engine shroud in place? That poppet has a little thing-a-ma-gig that you can grasp to pull the center out. Really makes it easy to remove. If it is the same size then I (we) need to pick up one from the dealer to replace the one on the filter strap to make access easier in the future.
Max
Max
I changed my own for the first time on the Max this weekend. The filter is in the same spot as my 06 Altima, which made it very familiar. I know what you mean about the oil running out the filter when you are pulling it off. What I have always done with the Alty and did with the Max is use a plastic grocery bag and drape it over the frame underneath the filter. With the oil pan right under the bag, the oil hits the bag and drains into the pan. I then pull the bag down into the pan and no mess.
Well, I would suggest that you all do what I do:
Work smarter, not harder:
http://www.quickoildrainvalve.com/
Perfectly safe and highly effective-takes minutes and is worth every penny.
Last weekend I was doing oil change for the second time and noticed oil residue around the gasket, not too much but enough to try to tighten it some more. When I tried tightening the valve, the gasket got ripped (it is not copper or aluminum, but made of fiber). So, as a result I removed it until next oil change, when I will install it with a new gasket.
Before new Max, I had it on the '95 Max and wife's '05 Ody. The product works as designed and is a pleasure to use. I highly recommend it.
Max
Mine does not leak, so just order the one you think best fits your needs and go for it, it saves time.
litch
123
Jan 4, 2024 07:01 PM
