Portable DVD Player
Old Feb 23, 2009 | 08:08 AM
airwolf09's Avatar
Portable DVD Player
which portable dvd player are you using to play thru the car built-in screen?
I tried to find the one without the screen buit-in (only want the player) and small enough to use and connect it via the RCA connector in the armrest console. any recommendation?????? and where I can get it????
Old Feb 23, 2009 | 09:53 AM
Compusmurf's Avatar
Love my '09
Just curious, since video playback still only works when the car is in park and the parking brake engaged, what's the usefulness of this?
Old Feb 23, 2009 | 10:17 AM
airwolf09's Avatar
I create a mod for it using a couple of relays and switch. Therefore, I am able to view the movie while the vehicle is in motion.
with a flip of a switch everything is back to factory setting. flip it On and i can watch movie thru the car screen.
Old Feb 23, 2009 | 11:54 AM
bk2k3max's Avatar
Do you care to give us the schematic on your Bypass for this modification?
Old May 19, 2009 | 07:05 AM
dobleu-Cayey's Avatar
share your bread, airwolf09! - Can you be so kind and provide solution on how to view movies while vehicle is running?
Old May 19, 2009 | 10:58 AM
airwolf09's Avatar
I use 2 relays combined with the led on/off switch at the autopart so that I can bypass the circuit while in motion. When turn the switch to ON position, the circuit will then in the by pass mode which I can watch the video while in motion. If the switch is in the off position, then it set back to the factory setting which the car need to be stationary to watch.
Below is the diagram of wiring. Depend on the system you have you will see in the diagram wires. you need to cut the speed sensor wire and the Ebrake wire. Use the relay to give the negative or ground feed to the ebrake wire at the back of the radio. As for the speed sensor wire, it just simple break the circuit or continuity from the feed of speed sensor when the switch is in ON position. That will trick the radio to think that the car is stationary in one place.
When it in Off position the relay will simply join the wire continuity from the ebrake feed to the ebrake reciever wire at the back of the radio. Same thing go for the speed sensor. It simply join the speed sensor feed wire to the speed sensor wire receiver at the back of the radio. That will put back the factory wiring.
hope that help....or I can make you the relay circuit for a small fee if you like....which will have the 2 relays, switch and instructions...
Wiring Diagram for 09 max w/o navigation system
Wiring Diagram for 09 max with navigation system
Old May 19, 2009 | 11:03 AM
G9Max's Avatar
do you to take anything apart or cut any wires?
Old May 19, 2009 | 04:47 PM
airwolf09's Avatar
as i stated above, cut the speed sensor and the ebrake and connect to the 2 relay. i have to take the waterfall or the radio console off to access the wire in the back of the radio. without take the console off, i'm not sure how you gonna access the wires from the back of the radio?
Old May 19, 2009 | 11:58 PM
MaxLoverAz's Avatar
This works in motion however you better love movies for the price!
http://www.tvandnav.com/index.asp?Pa...ROD&ProdID=189
Old May 20, 2009 | 04:10 AM
ANNINO's Avatar
This tool looks more like what i'm looking for, except without all the bells and whistles. I don't need inputs. I just want an interface that avoids cutting but bypasses the nav lockout. This unit doesnt even mention that. It says the video from its own input is able to be played while in motion. I wonder how much the factory male/female navigation harnesses cost or where to get them? I think i'd like to make my own harness using airwolf's plan but with harnesses in between. That way all the cutting is between the two harnesses and not the vehicle's actual system. Anyone know where to get these parts?
stevesmax
Dec 17, 2020 11:57 AM
Umer95SE
Dec 18, 2000 08:31 PM
MidnightMarauder
Dec 6, 2000 06:36 PM
Umer95SE
Oct 14, 2000 08:06 PM
