My auto up on my front windows does not work
Old Jun 30, 2009 | 09:02 AM
Chio's Avatar
I had my car in for service and now my window will not roll up auto i have to hold the button. what the hell happen.
Old Jun 30, 2009 | 09:07 AM
Mreim769's Avatar
Try searching I believe this issue has been covered as I had the same problem. Not quite too sure what caused it.
Old Jun 30, 2009 | 09:08 AM
09Maxima_Sam's Avatar
They disconnected the battery and now the windows have to be reprogrammed to allow the auto function to work.
Check out page 2-43 of the owner's manual.
Old Jun 30, 2009 | 10:29 AM
MaxLoverAz's Avatar
Is the passenger window supposed to have this feature also? Only my drivers side works.
Old Jun 30, 2009 | 10:38 AM
Only if there is a letter A inside the window graphic on the switch. Those without an "A" don't have the auto features.
Old Jun 30, 2009 | 12:51 PM
Chio's Avatar
yup that is what happen! i will look at the manual after work! thanks!
Old Jun 30, 2009 | 01:26 PM
BMWHIGH1's Avatar
it happen to me. All you have to do is hold the window auto button down for about 10-15 secs. Then do the same thing going up for 10-15 sec. It may not work right away but it will kick in.
Old Jul 1, 2009 | 01:05 AM
lightonthehill's Avatar
ALL '09 Maximas have the 'auto-up&down' feature on BOTH front door windows. Maximas with the Premium package also have the 'auto-up&down' on both rear door windows.
Old Jul 1, 2009 | 01:08 AM
Also keep in mind that disconnecting the battery can wipe out all prestored radio station settings, as well as discombobulating the sunroof. The Owner's Manual addresses both of these situations.
Old Jul 1, 2009 | 10:15 AM
KillaKam's Avatar
Put your car in the on position with the window rolled all the way down then roll it up but hold the switch as if you wanted the window to go up for 15 seconds after it closes. Shut of the Car and start and your problem is fixed.
Old Jul 1, 2009 | 10:28 AM
What is the one on the sunroof? I was not aware of that one.
Old Mar 7, 2010 | 08:08 PM
stevenlunardi's Avatar
simply put car into on position. Roll the window you wish to fix down, then roll window up and hold up the window switch for five full seconds, then release.
that happened because you probably disconnected the neg on your batt.
Old Jan 2, 2011 | 08:47 AM
BBmaxi's Avatar
Unhappy
so it looks like I got this fixed, at first the AUTO UP click on the windown switch was not working, only the regular window up mode worked when you had to hold the switch.
at first I tried to apply the fix and I guess I held the button to long and the power window driver side completely stopped working. It would work a little bit and stop. the longer I left it alone (I guess for the motor to cool off) the more power was stored and would start to work again...little by little.
so this morning after a few hours, I did the nissan windown restore function again and now fortunately it works. the auto mode now works.
so far the car is ok but wow there are just way too many things that can go wrong with this car. I'm affraid to know what will happen in the next few months of ownership.
Old Jan 2, 2011 | 01:40 PM
Compusmurf's Avatar
Love my '09
BBMaxi, keep your manual handy. Cars are so computerized now that when you lose power, everything needs reprogramming. I had to redo my windows, reconnect my cell, transfer phone numbers, etc. Worst off, I had my seat, steering wheel perfect and lost those settings too.
For the brave folks, there's a "super secret" diagnostic mode that you can do other changes like camera angles, and such for cars that have the full display. Not sure it's on all the cars, but it's there on mine. (Color display, Nav)
Old Oct 20, 2011 | 01:14 AM
09MaximaSV's Avatar
I experienced the issue. According to my manual, power the car to ON, then lower the window, then raise the window, hold the UP button for 3 seconds after it's fully closed, and then the setting is restored. Worked like a charm.
Old Oct 25, 2011 | 09:25 PM
ADAMdlc's Avatar
I just did it. It worked flawlessly! I did it to all four I didn't even realize that I had auto up on all four windows! I had to disconnect my batter before because the security system immobilized the car and I couldnt operate anything so yanked the battery and i was able to ten on the car
Old Oct 28, 2011 | 04:47 PM
bryansuavo's Avatar
thanks this happened to me
Old Oct 29, 2011 | 12:07 AM
Might need to reset your sunroof also.
Old Oct 29, 2011 | 03:05 PM
fredmc2020's Avatar
How did you get into diagnostic mode?
Old Oct 29, 2011 | 08:02 PM
Compusmurf's Avatar
Love my '09
Follow these steps to enter [at your own risk] into the diagnostic mode.
- Start Engine [required if you want to see all available diagnostic options]
- Turn OFF the Audio system
- While pushing the SETTING button, rotate the radio's VOLUME control either clockwise or counter-clockwise 30+ clicks.
- You will then be put into the diagnostic mode.
- Use the BACK button to get to previous screens.
NOTE:
Holding down the SETTING button and rotating the volume **** a 2nd time will put the diagnostic mode into a more "detailed" state offering more options.
Old Oct 30, 2011 | 06:10 PM
tundradave24's Avatar
what sort of options are in this advanced diagnostic menu ? anything in particular that is usefull ? or that i can really screw up the car with? thanx
Old Oct 30, 2011 | 06:39 PM
Compusmurf's Avatar
Love my '09
Look but don't change. LOL
Old Nov 13, 2011 | 01:57 AM
Mikky's Avatar
thanks for this post... all 4 of my windows are automatic... and the back passenger side didnt auto roll up,,,, i did the hold 10 second down and then hold 10 second up and it works like a charm.. back to normal.. thanks guys
Old Apr 15, 2012 | 12:35 AM
salazar1's Avatar
Cool
thanks for this post, it happened to all4 of my windows and they are all working again
Old Jun 8, 2012 | 07:16 AM
sparky1562's Avatar
Just bought my 2011, the back auto up but not the front. will have to see if this does the trick for me as well. Thanks Org!
Sweet! They all work now!
Old Mar 4, 2014 | 12:26 PM
SladeZero's Avatar
Awesome, I had the car lock down on me yesterday because the battery was low... wouldnt jump... changed battery... everything is fine now. Any ways... i was trying to figure out how to get my windows auto up'ing again.
THANKS.
Old Mar 16, 2014 | 04:42 PM
Volkster23's Avatar
Thanks everyone. Got my driver's side auto window working again too. Oddly, my battery was never low or dead. None the less, all is good now.
Old Mar 25, 2014 | 06:58 AM
C2020's Avatar
thanks for the info
I just got my 2010 back from the body shop and I was a little frustrated that the auto up function didn't work anymore. Thanks to this post it now works fine. This forum contains a wealth of information found no where else.
Old Apr 1, 2014 | 08:26 PM
Terrigno's Avatar
Just had this problem. And this post helped me solve it. Thank you guys! Love this forum!
jerrod99_se-l
Aug 27, 2015 08:27 PM
doctorpullit
Aug 20, 2015 05:15 PM
KGMtech
Aug 18, 2015 09:21 AM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
