LED's under the headlight
Old Apr 21, 2010 | 08:21 PM
jboss10's Avatar
you can barley see them...even in the regular pics
Old Apr 21, 2010 | 10:31 PM
trix_05's Avatar
Pretty nice. I like that they are much more subtle than others I've seen.
Old Apr 21, 2010 | 10:54 PM
jboss10's Avatar
The pics below. You can see a night version and see them in the day. Not very noticeable for an inexpensive kit. I wasted about 12". Dang!!!!!
Old Apr 21, 2010 | 11:11 PM
jboss10's Avatar
Old Apr 22, 2010 | 08:30 AM
OculusX's Avatar
Nice...What kit did you buy?
Old Apr 22, 2010 | 07:08 PM
PetitFrereMaxima's Avatar
Yeah, I asked the same thing. What kit did you buy?
Old Apr 22, 2010 | 07:10 PM
smarty666's Avatar
Very cool man, but I think a better description for the thread would have been LED's next to the fog lights!
Old Apr 22, 2010 | 08:27 PM
jboss10's Avatar
started: LED's next to the fog light.
Old Apr 22, 2010 | 08:39 PM
jboss10's Avatar
$16 kit from Autoparts.
Old Apr 25, 2010 | 06:36 AM
Erock1500's Avatar
LEDs
can you post how the install was performed?
Old Apr 25, 2010 | 09:28 PM
jboss10's Avatar
sorry Erock. I did not take pics, but It was VERY easy. You do have to take out the panel just in front of the tire to complete. The rest is a breeze. To all the HOT WIRE to the fogs is the BLACK not the white with the red stripe. Nissan dealers are stupid at least the one I called. "sir which it the HOT on the 09 Maxima fog lamp??? The white with the red dude. ARE YOU SURE. Yes sir positive" Freaking wrong. I had a tester, but for some reason could not find a good ground. They work perfect and have been through a rain and two car washes so hopefully the will hold up. Hit me for any more install questions.
Old Apr 25, 2010 | 09:40 PM
jboss10's Avatar
The kit looked like this except it said WHITE for the color. There were two strips of tape LED that were about 12" long ea. They had two lead wires, but I don't think that's the exact one. Mine were straight in the packaging. **NOTE*** had a test button to try them out!! The 3M tape holds GREAT. I was a little skeptical, but it does hold!!!
http://www.autozone.com/autozone/cat...andName=Alpena
Old Apr 26, 2010 | 08:33 AM
KillaKam's Avatar
Ok so I just wanted to make sure that I got you correctly, lol. The HOT wire is actually the black wire and the ground is the WHITE or did you ground it to a screw on the chassis somewhere? What did you use to connect the wires?
Old Apr 26, 2010 | 09:23 AM
SlkMax's Avatar
Question Link
Whats the link please?
Old Apr 26, 2010 | 12:04 PM
jboss10's Avatar
Spliced them straight to the fog wires. Yes the fog black wire is hot and the fog white wire with red markings is ground. I used "easy splice" so there were no cutting of the OEM wires. Make sure the gauge of the splicing connector is small enough for the LED leads. Those are VERY small gauge.
you can also cut and wire nut, just be sure to tape them good. Also before you stick the LED put a small amount of black or clear silicone over the end that you cut to seal it.
good to go.
Old Apr 26, 2010 | 12:05 PM
jboss10's Avatar
Read post#12
Old Apr 26, 2010 | 08:42 PM
KillaKam's Avatar
good to go.
Awesome man thanx for that feedback; I am going to try that out once the wether gets better been raining a lot here in CT.
Old Apr 26, 2010 | 08:58 PM
jboss10's Avatar
this should become a sticky.....JK Jundi's spoiler install was made a sticky with less info than I just gave)
Old Apr 26, 2010 | 09:39 PM
coldfear13's Avatar
Looks nice, kind of like the Porsche Led's
http://www.semiconductor-today.com/n...LY_06/af_p.jpg
http://www.vividracing.com/catalog/w...ledlights1.jpg
Old Apr 27, 2010 | 12:11 AM
VTenge's Avatar
Has anyone thought about wiring up LEDs as DRLs? Also has anyone tried to put LEDs directly beneath the headlight?
I'm currently 3,000 miles away from my car so I can't check myself but I can start looking up stuff to buy if there is enough space. There are flat LEDs that could probably fit into a tight space even it if required custom making the strips I think it would be worth it.
http://www.avagotech.com/pages/en/le...ngular_series/
doctorpullit
Oct 28, 2019 10:58 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
