Service manual around yet for 7th gen?
Old Jun 1, 2010 | 11:58 PM
2o4Max's Avatar
Just curious if the service manual for a 7th gen maxima is available. I don't think anyone has ventured far enough yet on the 7th gen to take pictures of it taken apart. I'm just curious to see if they exhaust system design is the same as a 6th Gen.
Old Jun 2, 2010 | 03:47 AM
ANNINO's Avatar
http://www.nicoclub.com/FSM/maxima/2009/
Old Jun 2, 2010 | 04:14 AM
Flip2cho's Avatar
2009-2010 service manual CD
http://cgi.ebay.com/ebaymotors/2009-...e#ht_500wt_948
Old Jun 2, 2010 | 09:55 AM
2o4Max's Avatar
Just as I had expected... they still haven't changed the exhaust manifold design to relocate or change the pre-cats... Maybe the Infiniti G series even has the same or similar design, anyone know off hand?
Old Jun 2, 2010 | 10:54 AM
NmexMAX's Avatar
dot dot dot ...
Is there any reason to change it?
Wondering what you mean, specifically, by same design. The layout is obviously different, as well as location since the Maxima is FWD and the G is RWD.
Old Jun 2, 2010 | 02:50 PM
2o4Max's Avatar
No just wondering about the exhaust manifold, the problems with 6th gens I would think are still inherent in the 7th gen and Infiniti G's. After reviewing the drawings they all have the same setup with regards to the pre-cat locations. I don't think they want to really address the issue of pre-cats failing just after the warranty period or a little before.
Old Jun 3, 2010 | 05:23 AM
dauntlessmax's Avatar
I know exactly what you're saying..
Old Jun 3, 2010 | 02:59 PM
carlosrg's Avatar
VSS and brake signal
Hi can someone with a service manual point out to me the VSS the vehicle speed signal and the brake signal that goes into our nav/stereo unit. I like to put in a DPDT switch so I can bypass the security feature of not being to watch DVDs while moving, and etc.
If there is some write up already can someone link it I haven't found it yet.
Thank You
Old Jun 4, 2010 | 06:12 AM
NmexMAX's Avatar
dot dot dot ...
Thank You
Why don't you use the FSM link provided?
Old Jun 4, 2010 | 07:54 AM
09Maxima_Sam's Avatar
I wish there was a paper copy of the service manual for purchase as well.
I have the pdfs linked above, but I am not about to print 3000+ pages off on my printer.
Old Jun 7, 2010 | 10:07 AM
NmexMAX's Avatar
dot dot dot ...
Get a laptop Take it with you .... no need to print it.
Old Jun 9, 2010 | 09:43 AM
rozo's Avatar
I did the ebrake/vss mod for video in motion/programming nav while in motion for a 2010, I brought it to my local car shop, behind the radio is a 32 pin connector. Green and red wire is the e brake, violet and white is the VSS. We put regular on and off switches for both(probably could have just grounded e brake), and it works fine.
Old Apr 1, 2019 | 08:43 AM
2011_maxima's Avatar
well i know this is a old thread, but i will try anyways i have downloaded the FSM for my 2011 maxima but i soon noticed that it DID NOT include the "EM" pdf portion... aarrgg. i am needing to replace 2 of the engine mounts & need the "engine" portionof the manual. by chance would someone have a pdf version that i could "use" orknow a place/site that i could find the EM portion of the manual?
thank you in advance....
Old Apr 1, 2019 | 11:39 AM
mahanddeem's Avatar
See the 2009 section, contains everything
Old Apr 9, 2019 | 10:44 AM
mahandeem,
that worked perfect. thank you! i didn't think to go to previous version..... didn't see the trees cuz of the forest!..
thank you again!
Jfaze401
Sep 18, 2020 07:47 AM
Drzcocaleka
Oct 1, 2019 07:59 AM
kilo870
Jan 12, 2013 11:20 PM
DanNY
Feb 25, 2010 01:52 PM
