I bought Sylvania Silverstars for the headlights (both low and high) and fog lights and I am at a loss on how to install these things. Ive heard that the front bumper has to come off to get to the bulbs? Why would they make it so difficult just to replace headlight bulbs which is a regular maintenance issue? Any help would be greatly appreciated! Newb to the site here by the way, so be gentle! haha
PS This is a non-HID projector model.
You don't have to take the bumper off. Just remove the tires and the inner fender lining. I agree that it sucks we have to do this. Stupid design. Same for the rear lights, why should you have to remove the whole light to change a bulb.
Quote:
are you serious? i thought you can access the light from the trunk by taking out the panel
Man thats not as bad as I thought...the inner wells should come out fairly easily...and you can get to the fog lights this way too? Thanks for the input! The dealer wanted $200 to put in 4 bulbs (not including the fogs just the hi and low beams) so I didn't bother asking about the fogs. Crazyyy.
Which is why they make these cars so hard to work on so the dealerships can make MORE money...its ridiculous. I have a '90 5.0 Mustang GT and every time I work on it I feel like a real mechanic because everything is SO easy haha. This car has stumped me!
Quote:
You can get to the fogs by removing the plastic panel under the front of the car, it's pretty simple. Take a look underneath and you'll see what I mean.Originally Posted by nterrito
you dont need to remover the front wheel just turn them and remove the wheel well covers behide the light bulbs
Quote:
I put Silverstar turn signals in at the same time I put Silverstar high beams in, and all I did was remove the fenderwell on both sides. It's not too hard.Originally Posted by JCmaxse00
What about replacing the front turn signals? samE thing?
hey anyone know which bulbs for a 2010 maxima? check the sylvania site my car is the sv 2010 premium. so is my bulb the d2s or the h11
Quote:
does ur car have the hid or not if its not hid its h11 if it is its D2SOriginally Posted by earthseeker
so like i know this is a noob ? but...i got the regular halogen lights (h11) nd wanna put HIDs, wud i have to buy the whole conversion kit?
Foglights - you can get to these by removing the black plastic cover underneath the front bumper, it's held on by plastic clips just take them all off and remove it you'll see your fog lights and have plenty of room to work to mount ballasts or whatever.
Rear bulbs - yeah it's a pain but you gotta remove the tail lights. best way I found to get them out is to take off all the liner exposing the two bolts, take the screws off the bolts, and then just hammered on them with a rubber mallet until the light popped out. you want to be real careful if you're prying from the outside the edges of the tail light are thin and can break off easily.
Headlight bulbs - easiest way is to jack the car up one side at a time, take the wheel off, take the clips out and remove the fender liner. you can do it by just turning the wheel and pulling back the liner but it really makes it a pain trying to work like that. just jack the car up and pull the wheel off it takes a few extra minutes.
I changed the oem hids on my sv and it just doesn't look right..something happened with the adjustments and idk how to fix this..I was thinking about taking it to the dealer but I decided to ask you fine people
Quote:
its possible when you put in the new bulb its not sitting correctly and is angled. id first check to make sure the bulb is in right.Originally Posted by crimsonblack11
is it possible to jack up one side and turn the wheel in either direction that gives you better access to the fender well? I've done this on other cars when I worked at my families body shop. If u try this, put a stand under the frame, never trust a jack!
I usually have to jack up the car and take off the wheel to get enough room to work on the lights. I've tried just turning the wheel but it wasn't enough room for me to work with.
And +1 on don't trust a jack use stands.
Ghozt, do we have to buy an entire HID kit for the SV's, or will replacement bulbs (6000k, ect.) just plug and play with the factory harness? I don't want to buy a ballast if I won't need it.Originally Posted by Ghozt
I usually have to jack up the car and take off the wheel to get enough room to work on the lights. I've tried just turning the wheel but it wasn't enough room for me to work with. And +1 on don't trust a jack use stands.
D-SV, if you already have hid's which I believe the SV has then all you need is the bulbs themselves. That's what I did for my SV sport.
Base SV doesnt have HIDs, you WILL need a ballast or else you will create some serious electrical issues for yourself.
Quote:
I wll take a second look at them tomorrow then...I'm trading rimswith a kid I met on craigslist for my stock 18s and his gunmetal 19s so the tires will be offOriginally Posted by Ghozt
Quote:
I just want to make sure that when I tear everything apart, the new HID bulbs I buy will hook up to the factory harness and i'll be good to go. I've never swapped HID for HID, just only upgraded from halogen to HID.Originally Posted by funnyman82
Thanks for the info guys.
For bout a month now, my R HID headlight comes on for about 40 seconds then blinks off.
Dealer replaced the bulb at a cost of $197 yesterday.
Still blinks off after a few seconds, apparently after electricals warm up.
Now they say they will have to replace the ballast at a cost of $569.
Ah, technology.
Guess I'll be driving only in daytime for a while.
Anybody know where I can get a low-cost replacement that is OEM-friendly?
Ah, technology.
Ah, technology.
Ive gotten my past few sets of hids from vvme.com. Ive had good luck with them. Heres the link to the D2S kits. Originally Posted by BlackMaxima
For bout a month now, my R HID headlight comes on for about 40 seconds then blinks off.Dealer replaced the bulb at a cost of $197 yesterday.
Ah, technology.
http://www.vvme.com/search-result?ma...1&option_31=-1
So Is it normal that I have HID low beams and regular high beams? Also if that is normal is there a kit to convert the high beams to HID as well?
Quote:
Yeah it's normal. In order to make your high beams HID's you would have to retrofit them to a projector lens or else with them in the normal light reflectors you'll reflect all kinds of light also it isnt recommend to have HIDS in ur highs because they go on and off and HIDs arent bright right awayOriginally Posted by SkyGeek
Thanks PSU09MAXIMA.
I just ordered a pair of D2S 6000k bulbs from cardHIDkits.com for $99 for anyone who's looking for decent prices. Everywhere around me was between $99-$129 for a single bulb.
Ok so I ordered the Silvania brand HID bulb pair for $99, I'm seeing some brands online that I have never heard of for as low as $15. Has anyone tried these other brands? Are they good or crap?
Quote:
$15 yes crapOriginally Posted by SkyGeek
Quote:
If you want good hids go to ddm-tuning.com best website and its less expensive. I get all my hids from there for $40. It's worth itOriginally Posted by SkyGeek
Quote:
I had the Sylvania bulbs on my Honda Accord. These bulbs will only give you a whiter higher intensity light, they do not give you a further reach of your light beam. The reach of the beam is determined by the lens in the car. So the money you are spending just changes the color of your light beam and I do not think it is worth the extra money. When one of these Sylvania bulbs burned out I replaced it with regular Halogen bulbs. Save you money and the hassle of changing the bulbsOriginally Posted by SkyGeek
Quote:
Totally correct, but the next question would be, what retrofit or lens do we need to buy to replace it with our blurry one ?? I'm interested in this!! Also, how hard it is to open the light and replace the lens!Originally Posted by silberma
