Steering column screw caps
Old Mar 13, 2011 | 10:32 PM
cake90036's Avatar
Does anyone know how to remove the screw caps on the steering wheel column to take off the steer column(plastic) top and bottom covers? I am pretty sure they have a cut out on the right and left side but am having difficulty getting them off.
If someone knows a way to get these off without damaging the plastic it would be appreciated.
Old Mar 14, 2011 | 11:38 AM
EmeryH's Avatar
The access hole caps have opposing lip tabs and can be removed by prying/pinching. The caps will flex enough to easily pop off.
Both of mine kept falling out while driving and don't seem to fit well enough to be re-installed. I mentioned this last week while getting an oil change and the service tech couldn't re-install them either. They are ordering replacements and said not to worry - they will even replace the entire steering wheel if needed!
Old Mar 15, 2011 | 11:16 AM
cake90036's Avatar
Do you pry them open on the rounded side or the side or the furthest right(on the right side) and furtherest left (on the left side)
Old Mar 15, 2011 | 02:40 PM
Llfe's Avatar
this should help = http://www.courtesyparts.com/images/...99F1-A3501.pdf
*look at the last couple pages...the first couples pages show how to install fog lights
Old Mar 15, 2011 | 10:09 PM
cake90036's Avatar
That just says to pry it.. and I've tried that but I don't want to ruin the plastic.
Old Mar 16, 2011 | 09:23 AM
Llfe's Avatar
umm...i used these exact instructions to install the fog combo switch
how would you ruin the plastic??? it's like 2-3 screws and clips
Old Mar 16, 2011 | 10:10 AM
Compusmurf's Avatar
Love my '09
Just relax and do it gently. It's NOT an egg.
Old Mar 16, 2011 | 04:25 PM
jommbi's Avatar
I think the OP wants to know which side of the plug is safest/easiest to pry from. Think of the battery door on a TV remote control. If you pry from the side with the fixed tabs, the tabs may break off.
Are these tabs like that, or can you pry from any side and still safely pop them off.
Old Mar 17, 2011 | 02:42 AM
EmeryH's Avatar
The caps have a slight bend built in. You should pry from the lowest edge - imagine an exaggerated horseshoe shape: push in on the end of either "leg".
The plastic is fairly pliable so it should not break too easily.
Old Mar 17, 2011 | 08:30 AM
Llfe's Avatar
you pry them open on the rounded side...make sure to pull up and not diagonal
Miket2006
Mar 1, 2021 03:55 AM
05RLS2
Apr 14, 2016 11:49 AM
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
