D2 Coilovers Installed - Pics
Old Apr 8, 2011 | 09:37 AM
  #41
BBmaxi's Avatar
not sayin get M replica wheels, but if u can imagine something like this with your car already equipped for maximum slammage! If u can imagine it, your so close to it.
Old Apr 8, 2011 | 10:14 AM
  #42
white09maxima's Avatar
I totally get what ur saying and I can imagine it do u know what offset I would need to sit flush on 20s?
Plus I got a call from JM and he said that he made a mistake and that he cant find REAR camber bolts for a 7th gen anywhere, only fronts I was going to order the spacers today but will hold off
Old Apr 8, 2011 | 10:20 AM
  #43
BBmaxi's Avatar
20x8.5 (+30 to +35) and 20x9.5 (+30 to +35) will set u off nicely.
also if u go 20x9 and 20x10, raise offsets to about 5mm.
I think u can go as low as +20 with a 8.5 and 9.5 set up, and I'm almost positive it will work with only a rear quarter roll....but I haven't see it so I can't say for certain.
that's why the benz and bmw works so well with the a35, the standard fitments are the aggressive fitments for the a35 maxima.
Old Apr 10, 2011 | 05:58 PM
  #44
thanks. i like tucked tires so need to make sure I get 20s with the right offest to accomodate some tuckage
Old Apr 10, 2011 | 06:22 PM
  #45
2009maxima sv-sport's Avatar
my rear tucks on 22s with a 22x9 rim with a offset of 38mm
Old Apr 10, 2011 | 07:15 PM
  #46
ToroMax's Avatar
That is one beautiful Maxima! Doing a good job on it, real Clean.
Old Apr 10, 2011 | 09:17 PM
  #47
IFuXwiTuZ's Avatar
your rear shocks / springs are one piece ?
because my coilover kit (NOT FROM D2) is setup as the original suspension was, it seems that D2/K-sport thinks they know better then nissan how to layout suspension.
it does look good though i was wondering how my car looks with the stock 19's which i have sitting in basement, not i know not to put them on -=x
Old Apr 10, 2011 | 09:35 PM
  #48
blue_magicSE's Avatar
Wow this car is clean!
Toronto you say? Might be interested in your rims/tires when your ready to get 20's. Pm me I live just north of the city
Old Apr 11, 2011 | 03:33 PM
  #49
Thanks blue_magicSE. I wont be selling my 19's when I get 20's but thanx for the offer. I'm trying to plan a meet in the Hwy 400 & Hwy 7 area for May 7th or 8th. There is a thread in the Canada section on here. Hope you can make it out.
Old May 20, 2011 | 02:55 PM
  #50
dr_2010SV's Avatar
Thanks. Just waiting on spacers and rear camber bolts to arrive. No, they are not maxed out, still have another 1" up front and nearly 2" rear. As I stated above I will likely turn the front down another 1/4" and the rear 1/2" after adding spacers, rear camber bolts and pressing the rear quater panel lips
Just following up about the rear camber kit you mentioned. Is that something you ended up requiring for proper alignment after install?
Is this also something that D2 should include with this coilover package
or at least mention as a possible requirement to obtain proper alignment?
How much extra did it cost you?
Other than that was the installation fairly problem free?
Sorry lots of questions I know......but your the man to ask!
Old May 21, 2011 | 09:51 PM
  #51
bigdave333's Avatar
the max looks great on coilovers!
Old May 23, 2011 | 09:39 AM
  #52
Mista_Vanquish's Avatar
Very nice drop with the coil overs!
Old May 23, 2011 | 09:47 AM
  #53
BBmaxi's Avatar
another beauty of the a35, it can take in some low offset wheels.
those of you playing with off the shelf, non staggered wheels are totally wasting potential of the maxima a35
Old May 23, 2011 | 01:48 PM
  #54
BBmaxi's Avatar
hello what do u mean d2 and ksports are different ? I'm thinking of pick up some ksports, can u explain or are u just assuming and making things up ?
Old May 23, 2011 | 07:48 PM
  #55
I wasnt able to find a rear camber kit so I've been running it as is & had no problems. in regards to the alignment, the toe is within spec so the car runs straight. I have put about 1,500kms on since the drop and havent noticed any significant wear on the inner edge of the rear tires yet. I suppose if I was putting on a few hundred kms/miles a day it would be different. in regards to the instal, it was straight forward with no major issues.
Old May 24, 2011 | 05:08 PM
  #56
BBmaxi's Avatar
what the heck is going on
Old May 25, 2011 | 06:22 PM
  #57
rtitan's Avatar
d2 and ksport are setup with the shock and strut all in one in the rear. BC and Megan have a shock and the spring separate, just like the stock setup.
d2 or ksport
BC or Megan
Old May 25, 2011 | 06:28 PM
  #58
lblackonblackl's Avatar
SHIFT_my stick
perfect
Old May 25, 2011 | 06:31 PM
  #59
nismoSEXIMA's Avatar
beautiful
Old May 25, 2011 | 11:37 PM
  #60
rohanmax14's Avatar
So that mean ksport n d2 are best? Since they know how to layout the suspension.
Old May 26, 2011 | 09:04 AM
  #61
BBmaxi's Avatar
thanks ritan, that's good info. i'll go with megans.
d2 or ksport
BC or Megan
Old May 26, 2011 | 10:03 AM
  #62
rtitan's Avatar
either way you cant go wrong!!
Old May 26, 2011 | 11:30 AM
  #63
MAXXED_816's Avatar
That my friend is WINNING! [/charliesheen]
Old May 26, 2011 | 12:14 PM
  #64
BBmaxi's Avatar
we are all WINNING!! whoo hoo
Old May 27, 2011 | 09:30 AM
  #65
LMAO. Thanks bro. I like WINNING
Old Jun 13, 2011 | 11:31 PM
  #66
SHADEZZ's Avatar
Just having the adjustment settings would make me happy....This will be a future mod of mine. Great Stuff!
Old Sep 9, 2011 | 02:27 PM
  #67
Papermate's Avatar
question... i installed the d2 on my 2011 max... but am i suppose to remove the old springs in the rear and leave nothing since on the 2011 the strut and spring are independent in the rear? or do i leave both on?
Old Sep 9, 2011 | 05:35 PM
  #68
whit's Avatar
Originally Posted by BBmaxi
ya it's kinda pointless being that low on stock wheels.
may as well get some nice fitting wheels to match.
agree 100% , altho im not a fan of dropping the stance of a car, ive always had nothing but issues in the past and personally wouldnt waste my $ coilovers etc...one thing ive learned thru many cars- there a money pit..i only do Rims/tires now...
Old Sep 9, 2011 | 06:15 PM
  #69
rtitan's Avatar
take out the old spring, since its a strut/spring combo it replaces the old spring.
Old Oct 30, 2011 | 04:44 PM
  #70
Stlbluzoo11's Avatar
That maxima looks great on coilovers. I had tein coilovers on my civic si. that car was slammed. I would like to go cheap and get springs only, but with my experience only doing springs will blow out your shocks eventually. Coilovers are the best. I am not sure if i want to kick out $1,000 for coils.
Old Feb 8, 2012 | 06:23 PM
  #71
bryansuavo's Avatar
d2 or ksport
BC or Megan
Going back to this.... which set up is better?? D2 or BC?
Old Feb 8, 2012 | 07:20 PM
  #72
VQtHuRtY's Avatar
Ride looks lovely! Keep us updated with the mods...
Old Feb 8, 2012 | 08:17 PM
  #73
Papies01's Avatar
i got d2 and im slammed and i love it
Old Feb 9, 2012 | 11:05 AM
  #74
tAdAaA's Avatar
My k sports blew and i just bought Megan for mine k sport sux
Old Feb 9, 2012 | 11:15 AM
  #75
Jbling700's Avatar
Hey Papies, I saw your Max and I love it. Where did you get your lip painted? My car is the same color as yours. I'm located in NJ also.
Old Feb 9, 2012 | 03:56 PM
  #76
Papies01's Avatar
if you are serious about doing it i cant refer you to my guy the lip is molded on by the way. the place is called newlife II 103 vesey st newark nj.. you have seen me on the road or on the forum?
Old Feb 9, 2012 | 05:08 PM
  #77
Jbling700's Avatar
On the forums in the rims mega thread. If I see you on the road I might crash I get easily distracted if I see a sexy Maxima on the road. And thanks for the info. Saving up for a lip and I need a place I can trust to give me the correct matching color. I have to see your Maxima one day. It's probably more stunning in person.
Old Feb 21, 2012 | 08:02 PM
  #78
tAdAaA's Avatar
Megan is THE best, thi coming from somebody who has Owned Ksport and eibachs (a joke)
Old Feb 21, 2012 | 10:53 PM
  #79
Papies01's Avatar
d2 are beast just like megan
Old Feb 22, 2012 | 06:24 AM
  #80
BBmaxi's Avatar
Megans r decent, there r a few things u gotta watch out for when setting up and instaling
