Megan Racing Coilovers
Just wanted to share my findings... Found this system while I was searching for stuff for the STI that I will be purchasing soon.
Product Information:
SPECIFICATIONS & FEATURES:
APPLICATION:
Nissan Altima 2007+
Nissan Maxima 2009+
SPRING RATES:
F: 62mm ID; 180mm length; 8 kg/mm
R: 62mm ID; 190mm length; 10 kg/mm
DAMPER SPECS:
F: 120mm stroke; 280mm length; M2 valving code
R: 147mm stroke; 260mm length; A1 valving code
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coil over damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
- Coil-Over was tested on a 4cyl vehicle. Will need a higher spring rate for V-6 models.
MSRP: $999.00
Megan Racing Street Series Coilovers System (Fits 07+ Altima/09+ Maxima):
APPLICATION:
Nissan Altima 2007+
Nissan Maxima 2009+
SPRING RATES:
DAMPER SPECS:
- Aluminum Brackets
MSRP: $999.00
Friends of mine that have used them on previous Maximas always talked highly about how good there products were. To each his own though; shoot them an email maybe them will send someone a set for free to do a review on. If I had my Maxima that is what I would do. Better to beat everyone to the punch so maybe you get a discount or even a free set
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 23, 2015 08:31 PM
