Mirror Memory
Old Apr 20, 2011 | 08:02 PM
steevo's Avatar
Mirror Memory
Occasionally, after driving in reverse, my side view mirrors will not reset all the way. They end up tilted lower than where I had them set in memory. Whats really annoying me, is I had this same intermittent problem on my 2005 Maxima and they could never fix it. The 2005 did not have reverse tilt, but did have memory. Every once in a while I would start the car and the mirrors would end up aimed down.
Putting the car in park and pressing the memory button still sends the mirrors back to where they belong.
Also, I could swear this has also happened with the steering wheel setting itself slightly lower than the memory setting.
ANyone else experience this or get it fixed?? I hate to have them mess with it and start replacing parts because I have a feeling they will not be able to figure it out, just like what happened with my 2005.
Its simple enough to flip into park real quick and press the memory button to fix the mirrors.....
Old Apr 20, 2011 | 10:21 PM
Car Addict's Avatar
I've seen other people state that same steering wheel problem. I'd take it in while it's still on warranty.
Old Apr 21, 2011 | 06:36 AM
mrodenberg0124's Avatar
Yeah every now and then my steering wheel is slightly lower than what i have it set to in memory. Haven't had the issue with the mirrors though.
Old Apr 21, 2011 | 07:00 AM
steevo's Avatar
The steering wheel thing I am not positive about, but the mirrors keeps happening. I just broke 3000 miles so will be going in for my oil change soon.
Old Apr 21, 2011 | 09:07 PM
PSUFan83's Avatar
Just got my '11 Maxima last week. I've noticed that sometimes my mirrors tilt in reverse an sometimes the don't.
Old Apr 21, 2011 | 09:37 PM
iMAK's Avatar
They won't tilt if you put the mirror switch to neutral "center position" it shall work either on the left or right position.
Old Apr 22, 2011 | 07:19 AM
steevo's Avatar
THEORY ....Put car in reverse. The mirrors tilt when in reverse.. Then shift into drive and immediately pull away BEFORE the mirrors finish tilting back up. They stop because the vehicle motion sensor disables the memory setting??? Haven't been able to consistently reproduce this yet.
Old Apr 22, 2011 | 11:28 AM
PSUFan83's Avatar
IMAK, Thanks for the tip. That really helped and kinda makes sense (being able to turn the tilt feature on & off). :-)
Old Apr 22, 2011 | 09:19 PM
AbleRiot's Avatar
Where are you located?
Are you experiencing what happened to me a few months ago? My passenger side-mirror apparently froze out and needed to be replaced.
http://forums.maxima.org/7th-generat...lfunction.html
Apparently there is a 1 out of 20 frequency for the automatic windows to fail according to my service manager. I would bring it in for service, replicated or not, just to have them look at it and run tests. Failing side-mirrors getting a mind of their own isn't fun to drive with on the highway...
Old Apr 23, 2011 | 11:34 AM
steevo's Avatar
For me its both mirrors occaisonally will not come all the way back up. But my "Testing" seems to confirm that it will not happen if I wait a moment before driving off.
Old Jun 17, 2011 | 05:53 AM
Makc1kNYC's Avatar
Well 2 days ago I got into my car at night to drive my friend to a restaurant, after I dropped her off I noticed that my right passanger side mirror was turned more to the left. On the way back home I stopped and pushed the Memory Seat 1 button and it was strugling getting back to it memorized position. I hit the 2nd Memory Seat button and it worked perfectly fine! Today it happened again, so I don't really know what's the problem. I tried moving it around and pushed the 1 memory buttom nothing same thing but the 2nd one works. Any thoughts on that guys? I would really be appriciated if someone tells me what's up Thank You!
Old Jun 18, 2011 | 12:19 AM
lightonthehill's Avatar
Makc1kNYC - Strange one. If you checked and the glass mirror is not scraping against the mirror housing, I would first reset everything on the #1 setting again, and if the problem is still there, You may need a new mirror under warranty.
scutmud
Jun 30, 2016 05:16 AM
Bluenissan
Sep 20, 2015 08:54 PM
flu2000
Sep 8, 2015 02:23 PM
Maxilano
Aug 31, 2015 07:33 PM
wpr
Aug 5, 2015 03:28 AM
