best non permanent way to black out door handles
Old Apr 30, 2011 | 10:57 AM
BBmaxi's Avatar
is there way way to use the vinyl wrap thingy ? I don't want to spray paint it because that would be permanent. I'd like to be able to remove it in case the next owner prefers the chrome door handles.
Old Apr 30, 2011 | 11:03 AM
VQ'rInWLA's Avatar
Plastidip it. Its durable but can be peeled right off if needed be.
Old Apr 30, 2011 | 12:34 PM
Car Addict's Avatar
vinyl
Old Apr 30, 2011 | 01:02 PM
Vinyl or Plastidip.
Old Apr 30, 2011 | 03:38 PM
Ghozt's Avatar
vinyl would be easier to take off but probably harder to put on. wonder how plastidip works with the button you push to unlock the doors on the handles. also curious how it holds up over time since the door handles get touched quite a bit.
Old Apr 30, 2011 | 04:09 PM
Kmoney's Avatar
I wrap my door handle with vinyl. It was tricky but you definitely need heat gun to make the vinyl flexible.
Old Apr 30, 2011 | 04:12 PM
Ghozt's Avatar
whats the trick? do you heat and stretch the vinyl so that it fits curves? or do you hold the heat gun up until it makes the vinyl shrink and try to shrink it around the curves?
Old Apr 30, 2011 | 04:27 PM
Heat and stretch.
Old Apr 30, 2011 | 04:35 PM
Kmoney's Avatar
Heat and stretch.
Correct.....
Old Apr 30, 2011 | 04:48 PM
Ghozt's Avatar
Correct.....
did you have to make any cuts in the vinyl as you wrapped it behind the handles? you just overlap the vinyl behind it where it meets?
The Frye
Feb 3, 2019 08:34 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
