Eibach spring install
Old May 14, 2011 | 01:04 PM
maxxxxspeed's Avatar
Who has installed them and can give some tips or tricks? What all is involved? Do you have to use a spring compressor? Will one from autozone work?
Old May 14, 2011 | 01:20 PM
UGAd13's Avatar
here
Old May 14, 2011 | 01:40 PM
Nothing for 7th gens... Ate they all the same?
Old May 14, 2011 | 01:45 PM
Lsgun1's Avatar
Installing springs is pretty straight forward. Just compress them and remove the old strut+mount and swap everything on to the new ones while they are compressed. Just be careful doing it because if the spring comes out of the compressor is can cause some serious problems for the people involved.
Old May 14, 2011 | 01:52 PM
Ok... so its just like every other one... For some reason I didnt think we had coilovers up front. Thanks yall
Old May 14, 2011 | 06:30 PM
what the junk's Avatar
hey man just installed these yesterday myself. I did it with hand wrenches and $10 spring compressors from harbor freight. Tip: loosen the top strut assembly nut before you remove the entire assembly. It's the 18mm you see in the engine bay. Otherwise it sucks without an air gun. Biggest pain is that you have to compress the new springs too (haven't had to do that on honda or ford spring install) to install them. fronts prob take an hour each and rears take like 15 min each. It's pretty easy stuff.
edit: LOOSEN the top nut. DO NOT remove it. Just to clarify, as that will make your life miserable.
Old May 14, 2011 | 07:43 PM
Thanks for the tips!
Is the spring compressor you used the type that you use a socket wrench on to tighten and compress the spring?
Old May 17, 2011 | 01:45 PM
SNEEKYFAST's Avatar
Thanks for the tips. I just wish I could find the springs! Eibach is listing them on back-order until the second week of JUNE!!! I'm kinda impatient
Old May 17, 2011 | 01:54 PM
Kmoney's Avatar
check stillen.com
Old May 17, 2011 | 09:58 PM
yeah purchased from stillen, they have them in stock.
Old May 18, 2011 | 04:43 AM
SNEEKYFAST's Avatar
Thanks for the heads-up!
Old May 24, 2011 | 10:49 AM
Torque specs?
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
