Removed Negative Battery Cable
Old Jul 14, 2011 | 12:34 AM
DJ Zreik's Avatar
Hey guys, i installed my new intake and it required me to remove my negative battery terminal which to my knowledge resets the computer in the car? I noticed my odometer area is dimmer than usual and that my windows dont have the automatic roll up feature anymore... Any suggestions on how to get it back to normal?
Old Jul 14, 2011 | 12:48 AM
lightonthehill's Avatar
Its in the manual somewhere. Everything has to be reset. Sunroof/double panel roof, radio stations, windows, etc.
I seem to recall you roll the windows completely down, then roll them up and keep your finger on the up button for ten more seconds or something like that, then it should work. You may have reset each window individually.
I think you also have to hold the close button on the roof/sunroof down for ten seconds to reset it.
But I have never had my battery disconnected, so am half-guessing on all this. Lots of folks here have had their battery out, and will be able to tell us exactly what has to be done when they see this thread in a few hours.
Old Jul 14, 2011 | 01:07 AM
DJ Zreik's Avatar
Awesome thanks man, ill definitely look in the manual. But my moonroof is working so I guess that's not a problem. Still need to figure out my dash though...
Old Jul 14, 2011 | 04:56 AM
Ghozt's Avatar
Not sure about the dash, try adjusting the brightness maybe? Lightonthehill is right about the windows, hold it down for 10 seconds then hold it up for 10 seconds the auto feature will work again
Old Jul 15, 2011 | 08:52 AM
GM_Traitor3.5VQ's Avatar
The dash brightness gets reset as well when you disconnect the battery. Just twist the little black cylinder on the IP clockwise to turn your brightness back up. Easy as pie!
Old Jul 15, 2011 | 02:28 PM
Excellent deduction. I tend to forget that little A/B trip mileage resetting cylinder also controls instrument panel brightness.
Old Jul 16, 2011 | 10:06 AM
Maximum Drive's Avatar
Did it wipe out your music saved on the hard drive?
Old Jul 16, 2011 | 11:14 PM
I haven't had my battery disconnected, but feel sure doing so would have no effect on what I have on my music box hard drive (many dozens of albums).
Old Jul 19, 2011 | 07:45 AM
Hey, nobody is perfect
So, in short; disconnecting the battery will cause the following items to be reset:
1) Auto-down feature on windows
2) Radio station presets (and any fade/balance/treble/bass settings)
3) Instrument Panel brightness (both day and night settings)
4) Short term fuel trims (back to factory default)
5) Transmission programming (back to factory default)
Old Jul 19, 2011 | 12:01 PM
em_aych's Avatar
Info on this?
Old Jul 19, 2011 | 12:14 PM
Originally Posted by em_aych
Info on this?
All newer transmissions have a 'learning' feature that adapts to your driving style. The cycle for the CVT is much shorter than a normal geared transmission since there are no shift points in the CVT.
I've had to disconnect my battery twice and I can tell you that each time I take the car out for a drive after doing so, it feels a bit sluggish. Throttle tip-in is slower, doesn't have the same feel as before. The sluggish feel is also attributed to the ECM re-learning the fuel trims for your driving style as well. If you usually rip it to redline frequently, you'd definitely notice a difference right off the bat.
My 2001 Grand Prix for example shifted like an old Cadillac after disconnecting the battery. After about a week or so of my normal driving habits, the TCM and ECM caught up to speed again and all was normal.
Old Jul 19, 2011 | 06:17 PM
em_aych's Avatar
oh ok i gotcha.
hopefully it doesnt take too long with the 7th gen to relearn everything. . .
Old Jul 21, 2011 | 11:16 AM
DJ Zreik's Avatar
Oh my God, I love you! No homo of course... lol, but this has been happening to me and I was like wtf is happening!? I guess I just have to drive it more often for it to get back where i want it too. Thanks for the help!
Old Jul 21, 2011 | 11:57 AM
Hahaha, no problem dude. Glad I could help. After a couple hundred miles, car should feel as it did prior to resetting the ECM.
Old Jul 22, 2011 | 07:42 AM
Ghozt's Avatar
Interesting, I didn't know this either. Wonder if this also learns a little from the mods you put on, cause its been over a week since I got the Borla on and it definitely feels like it pulls harder now than it first did. Also good to know that when I put the Y pipe on I should wait a week or so before gauging the results. Thanks man!
Old Jul 22, 2011 | 07:58 AM
See, good things come to those who are patient and let the computer sort everything out in due time
knight_yyz
Oct 24, 2015 08:05 AM
Noela
Sep 26, 2015 08:22 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
