Weird Noise
Old Aug 11, 2011 | 09:22 PM
Makc1kNYC's Avatar
Weird Noise
Everytime I drive making a right turn or on the green light i go or stop I have a weird sound comming from my front right wheel. It sounds like a RUUMp, like you take a shovel and scrape it against the floor. Not loud or anything just weird and I know its not suppose to do that. Anyone can help me out on his one please. Thank You!
Old Aug 11, 2011 | 10:04 PM
chrome91's Avatar
take a look and see if anything is scraping from behind the wheel, the cars too new to have any real mechanical problems lol
Old Aug 12, 2011 | 08:12 AM
vr4z06gt's Avatar
Your inner wheel fender, the piece of plastic in your wheel well, might also be loose??? Could...maybe....be a hub but you should also expect some road noise on the highway if that is shot.
Is your car under warranty? If so, bring it to the dealer and let them figure it out.
Old Aug 12, 2011 | 08:22 AM
Makc1kNYC's Avatar
No when I drive it's perfect. But when I stop and go or make a right turn it has that noise I don't know how to describe it like plastic clunk or something. My car drives normal it has no signs of anything broken... That's what I think. It's under warranty but I'll let me personal mechanic check it out first. Car is leased but I lowered it with Eibach's it has nothing to do with springs because I had that sound before I installed them. It wasn't like that every stop and go like right now, only overnight when I started the car left my p lot and it just clunked once and all good now it's everytime I stop and go. It's bugging the **** out of me!
Old Aug 12, 2011 | 08:58 AM
GM_Traitor3.5VQ's Avatar
I had roughly the same sound in my 2010 when making right turns. Dealer replaced the upper strut insulator mount and an insulator on the top of the coil spring which got rid of the noise.
Old Aug 12, 2011 | 09:42 AM
Makc1kNYC's Avatar
Did your car drove diff when that was happening? And how much u think that would cost?
Old Aug 12, 2011 | 09:58 AM
Nope, drove perfectly fine except for the clunking noise. There's actually a TSB (NTB10-020) for this issue.
Old Aug 12, 2011 | 05:49 PM
vr4z06gt's Avatar
If your car is under warranty, and you didn't cause the problem (pot holes usually don't count, but performance mods could depending on the dealer), then it becomes Nissan's problem to fix the car. Just be polite, especially since there is a TSB out, it shouldn't be hard to get fixed and at no cost.
I actually had the same problem with mine, took it to the dealer, showed them on a road test, they fixed it no problems asked. Most need the work with the industry being so slow so they will be happy to fix whatever they can.
Old Aug 13, 2011 | 10:16 AM
speedstick345's Avatar
Could be a defect, get it fix if you still have warranty.
Oh yeah, might be a ball joint problem?
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
