Subwoofer box help
Subwoofer box help
I need some help I wired up a aftermarket sub and everything is finished except the part where I can't find the wire behind the stock radio that turns the Power on and off to the amp ? Any one install a amp before ?
You can just get an Add a Fuse and attach it to an empty fuse location on the drivers side fuse panel. Very easy and no need to remove the radio.
http://www.amazon.com/Bussmann-BP-HH...uct/B000GKEXK2
Looks something like that and can be found at any radioshack/autozone/advance auto parts, etc.
I believe you are speaking of remote turn on wire from the deck. It is usually the blue wire on the rear of the deck. No need to place a fuse inline.
another option is to splice into the control wire that goes to the amp in the trunk, thats what i did and it turns my amp on/off when the sound system turns on normally. if you want I can go look at what color wire I spliced into for that and let you know, then again that'd only be helpful if you have a 7th gen
7th Gen. A/V wiring diagrams:
http://www.nicoclub.com/FSM/Maxima/2010/AV.pdf
it's a light blue wire. my wire is the thicker solid blue one, so ignore that. you'll have to strip off some of the wire sheath to get to it, it's the wire harness coming out of the back of the amp thats mounted to the trunk ceiling
Still a good idea to have an inline closest to the power source. If the wire get's shorted to ground it could blow the head unit...
you do NOT use a fuse on the control (remote turn on) wire that tells your amp when to turn on/off. not sure if that'd make it not work or just be a waste, but ive never heard of using a fuse on the control wire it doesnt carry that much current.
It carries enough power to blow the circuit in the head unit if you should short the wire to ground. Best practice is to fuse it close to the source, always.
Of course you can get by without it, but don't crimp the wire under a seat or putting back in a trim panel and make contact with ground...a fried head unit is not uncommon in those circumstances...
Are you suggesting putting an inline fuse on a 12V remote turn on wire? Seriously? I have never heard of this practice. But hey whatever works! I am perfectly fine without running an inline fuse as I don't see the need for it. What are the odds that I will short the wire out to blow the deck? I will take my chances....
What size fuse would you put inline? Like I said before I will take my chances without as I just don't see the need for it.
Years ago aftermarket stereos would come with the inline fuse assembly already on the remote turnon wire. 0.3amp was typical as I recall. Things may have changed since then, protected circuit perhaps, but we're talking about power from a factory head unit, why would you take any chances? It's positive power period, and without a break point, you're forcing all catastrophic shorts to occur inside the factory head unit. Even with a 1 amp fuse I'd feel more protected then with nothing...
I have never had an issue with the remote wire burning out the HU. I see your point of protecting yourself but it isn't like the wire is going to move around to get pinched to create a short. Can it happen? Sure, but what are the odds of that happening?
Sure, how often does it happen...I can't remember the last time I blew a fuse, but if anything does go wrong, I'm wearing protection on all my positive power wires...
lol Like I said putting a fuse in line with the remote turn on that's all on you guys. If the remote turn on is ran properly and is secured it won't get shorted. But do as you must....
There is no right or wrong in this case!!!
Just installed a system in my car and I tapped into the bose amp with this...
http://www.sonicelectronix.com/item_...AC-SNI-15.html
Best way to do it IMO...
Stagnet04
Sep 14, 2015 11:28 PM
