2010 maxima wont start. HELP!
Old Nov 12, 2011 | 07:08 PM
bigjoe's Avatar
hey guys i have a 2010 maxima premium fully loaded 18000 miles only like a year n half old. well my car goes to start up and it makes a sound like its trying then sometimes it goes threw and starts up and other times it just straight out dies. but when it dies it makes a ticking sound but my fog lights are on sometimes or my directionals are one. i dunno if its a shortage and nissan once again ****ed something up lol. please help any1 ever have this problem?
and also how many people keep getting that rear end squeek that they claim they fix and keeps coming back? lol
just my luck, thanks guys
Old Nov 12, 2011 | 07:18 PM
rh0214's Avatar
Sounds like a bad ground or battery. The fogs will come on because it doesn't take that much power to turn them on but there isn't enough behind the battery to start the starter. So th clicking should be the starter. You have any after market wiring work or anything done to it?
Old Nov 12, 2011 | 07:24 PM
bigjoe's Avatar
its all stock only aftermark is theres tints. Its the wierdest thing. im thinking theres a shortage or something. there wasnt anything wrong with the car until i brought it in for a squeek in the front and they something called a " straight time for dash rattle repair". now im having this problem
Old Nov 12, 2011 | 08:42 PM
BIG6988's Avatar
Im thinking bad ground or u just might have a dead cell in the battery Pep Boys will check ur battery for free and can put a load on it while testing it I also have a 2010 max with the sports package and when i go over a speed bump i hear a squeak it sounds like its coming from the right rear i did have a bent lower control arm in the rear dont kno how the hell that happened but after it was replaced i still have the squeek
Old Nov 12, 2011 | 09:00 PM
bigjoe's Avatar
Hey big, goes it possible for the ground to go bad now? Would it o happened to me in the past? I had the car for a year and a half. It could be the battery I hope it is... As far as the squeek goes its a common problem my dealership told me with the Maximas the way they designed them u get a squeek. The one in the rear is it on the passangers side? If so that's where mine is and it's a problem with the shock it's common it comes out in the cold but it should be fixed. It's a 40k car shouldn't be doing this ****. I also found Nissan to make this car pretty cheaply which I'm very sad about. Since I've only heard good reviews about Nissan.
Old Nov 12, 2011 | 09:02 PM
bigjoe's Avatar
Also look up recalls! There were a ton on 2010 models for shocks/coils that's the problem
Old Nov 19, 2011 | 05:49 PM
BIG6988's Avatar
thanks guys and i think the dealer is full of crap i kno a lot about cars and never heard IT IS DESIGNED TO SQUEAK actuallu in the sold it is getting worse
Old Nov 19, 2011 | 05:57 PM
BIG6988's Avatar
big joe where can i find that recall list been searching just cant find it please help
thanks
frank
Old Nov 19, 2011 | 06:03 PM
BIG6988's Avatar
i just read somewhere gant fricken remember that there is a grounding cable problem dont know if its making the recall list though but my mechanic said he heard the same thing and he gets inside tips from his friend sometimes dealers will tell u there is no recall till we find it print it out and bring it to them then they have to honor it they r all jerks
Old Nov 21, 2011 | 01:13 PM
sctriguy's Avatar
I'm actually having a similar problem. I just bought the car (an 09 Sv) that has spent most of it's life in the northeast. The previous owner had installed an optima yellow top in it which is great, however I noticed the positive battery connection was as tight as could be to the point of being deformed. I went to remove the positive battery cable today and the thing ripped in two! What a piece of crap! There is actually very little surface area of the post to contact the terminal. The problem may simply be fixed by removing the cable, cleaning and re-attaching. I of course had to order a new part. $13, but cheaper than a new battery.
Old Nov 21, 2011 | 04:05 PM
atlanta10's Avatar
This is so odd-same exact thing happened to me today when I left my car in the on position without the motor running. In other words I drained the battery for six hours and the fogs were on but no starting. In fact, I couldn't turn the fogs off so it was like some type of warning that the battery was drained. In addition, heard a ticking sound from the fuse box.
Jump start did the trick so with that being said, I would guess your battery is going out
Old Nov 21, 2011 | 04:13 PM
Ghozt's Avatar
my stock battery used to die really fast, thing was terrible. i replaced it with an optima yellowtop and no issues since. btw if u go optima dont get em off the internet; way too many people have gotten messed up batteries off Amazon and other sites and some dont accept returns (hazardous material) and you're stuck with it. yeah it'll be a lil more at your local autostore but it'll work...
Old Jan 22, 2012 | 01:17 PM
themark1's Avatar
*******PLEASE HELP**********************************
Help I have a similar problem. Yellow key light on. Cant turn on the accessory. Cant roll up windows (hard key doesn't work). I live in Alaska. 100 MILES FROM THE DEALER.
I've changed the car battery, the primary fob battery, and have tried the back up fob.
My brake lights do work.
I've noticed that the steering wheel lock is not engaging though.
All the while, though, the yellow light stays on while I'm seated in the car with either or both keys.
Yes I've tried to sit key in key boot. without any changes. Not even sure why they put that in the car.
Old Nov 16, 2014 | 09:35 AM
Poorfarmer's Avatar
Car won't start
I have a 2010 maximum went to crack it and won't crank padel is hard the warning key is on . I took the brake padel sensore off and rain a jumper wire to see if it was bad and it still don't crank ,undone the battery still nothing put emergency brack on and put car n neutral still nothing . Don't know what to do, I'm use to key start not push button can any one help me
Old Nov 16, 2014 | 01:54 PM
Texakinz's Avatar
I just had the same problem Monday. Car died at gas station and had it towed to dealership. Steering lock malfunction and vehicle will not recognized keys. $1600 later got my car back Friday.
Old Nov 16, 2014 | 01:58 PM
george__'s Avatar
That's brutal.
At least they fixed it quickly
Old Nov 16, 2014 | 02:31 PM
Richard66's Avatar
Steering lock malfunctions is the reason I pulled the fuse on that baby a year ago. Cost of repair doesn't enter into the picture as I have insurance, but what I really didn't want is to be disabled somewhere requiring a tow.
Old Nov 16, 2014 | 02:33 PM
JRod28's Avatar
Just got a 2014 with the Sport package with under 500 miles so far. Just noticed a squeek coming from the rear but haven't had time to investigate where it's coming from. Figured it was just the Sport suspension or the fact that temperatures have dropped dramatically the last couple of weeks in Chicago...
Old Nov 16, 2014 | 06:54 PM
Max2013's Avatar
Does anyone know if the steering lock problem is limited to certain model years or are all 7 gens susceptible?
Old Nov 17, 2014 | 03:49 AM
Akiyukio's Avatar
All 7th generations as well as other Nissan models that use the similar steering wheel lock are susceptible.
However, I think it is 2011s and onwards that had the fuse removed from the factory or the dealer pulled it.
Open the front hood of the car, and look to the driver side area, rear of the battery.
Open the cover to the fuse box, and turn the cover over a description of the fuse locations. Of the four rows of fuses, I think it's the one closest to the front of the car, passenger side. Should be a 10amp one if you have it, or none if it's already pulled.
Old Nov 17, 2014 | 07:56 AM
Max2013's Avatar
Thanks!!
TMartinLVNV
Aug 16, 2015 01:48 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
BassAddictJ
Aug 4, 2015 11:38 AM
Jcof88
Aug 3, 2015 10:43 PM
