Foud a neat trick with the paddles
Old Dec 1, 2011 | 03:19 PM
JimmBrooks's Avatar
I havent seen this posted anywhere so forgive me if it is a repost... if you leave the shift slector in D and use the paddles to downshift as when comming to a stop sign or having to slow abruptly, if you hold either of the shifters down, in 1 second it will automatically shift back to D in normal drive mode. This is much quicker than not holding the paddle down and letting the transmission decide when to put it back into D mode. Hope this helps those that use D mode most of the time and want to ocassionaly tap the paddle to make it do what you want in that specific moment without having to move the selctor and take your hands off the wheel.
Old Dec 1, 2011 | 03:30 PM
funnyman82's Avatar
Is ok to downshift using the paddles to slow down? I keep thinking it will mess something up...
Thx!
Old Dec 1, 2011 | 04:05 PM
Ghozt's Avatar
it is perfectly fine to downshift using the transmission (paddles or the shifter). i asked a Nissan master tech and they said the car actually does it on it's own a little when you brake.
Jimm - awesome info thanks! I always used to push my shifter from left to right to force my car back into D. This will be nice to not have to take my hands off the wheel anymore! Thanks!!
Old Dec 1, 2011 | 06:54 PM
JimmBrooks's Avatar
No problem, even though I cant contribute as often as you Ghozt I definitly enjoy supporting the comunity. General manager for best buy and a new daddy... My time used to be all about cars, now its a little more tied up...
Old Dec 1, 2011 | 11:25 PM
lightonthehill's Avatar
That master tech is absolutely correct. In both the 6th and 7th gens, as we start down a hill at low speed, if we are not depressing the accellerator, the car automatically begins applying engine compression via the tranny to slightly slow the car down.
I noticed this immediately when I began driving my 6th gen '04 SL, and was glad when I found the same system exists on my 7th gen '09.
howardis
Dec 11, 2019 06:10 PM
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
robtroxel
Aug 21, 2015 05:41 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
