Signal light mirrors
Old Feb 24, 2012 | 05:10 PM
eepowers's Avatar
So i'm planning on adding signal light mirrors to my maxima s. Ive been looking on rockauto.com for the mirrors, but they have a huge amount of mirrors. anyone have an idea of which ones i need??? I want ones that are heated, power, w/signal lights. Or does anyone know of another site to get the mirrors from?? preferably pre-painted??
Old Feb 25, 2012 | 05:35 AM
vr4z06gt's Avatar
I would make sure that the wiring harness is compatible with whatever you want. It isn't always the case that you can simply swap them out. Alot of times you will need to run new wiring to the fuse block, install fuses, and then to the switch that activates those features. I don't know what you have on the S model. I would guess you could look at the wiring diagram to verify the connectors between models to make sure this really is a simple project.
Old Feb 25, 2012 | 07:22 AM
bryansuavo's Avatar
I have a maxima S, i have opened the door panels when i did my audio install and i did notice alot more wires on the connector to the side mirrors. In my case, i think a mirror with blinkers works, but im not sure about the heated option since the car didnt bring a button or anything.. But as far as the blinkers, i think they do work.. So they should for you, now the extra bonuses im not so sure..
Old Feb 25, 2012 | 08:52 AM
Jbling700's Avatar
I remember reading a post a while back that someone converted their side mirrors into the signal ones but they had to run a wire and tap into the blinkers... Seems like a lot of work IMO... If I where you, go to the Nissan dealer and ask how it takes to convert it and pretend your interested to get the work done... Dealers tend to tell everything if you seem interested...
fastcarny
Oct 6, 2015 10:42 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
minsbang
Sep 11, 2015 08:48 PM
flu2000
Sep 8, 2015 02:23 PM
