Fuse for front power outlet?
Old May 10, 2012 | 01:24 PM
gofastgt's Avatar
My power outlet in my center console works just fine, but the front outlet (in the little square area) is not working. I did find a penny in it, which I got out, but don't see a fuse for it in the engine compartment. Is there another fuse box anywhere? Any other thoughts?
Old May 10, 2012 | 01:29 PM
MaximaSE96's Avatar
Maxima Owner
yea under the dash driver side there is a little access panel u pull out
Old May 10, 2012 | 01:42 PM
gofastgt's Avatar
Ok perfect, thanks for that. I'll have to check it out tonight
Old May 11, 2012 | 09:14 AM
gofastgt's Avatar
So I looked at the panel and the fuse was not in the correct slot, so I moved it over into the correct one, and it's still not working. The fuse is fine.
What now?
Old May 11, 2012 | 09:16 AM
PSU09MAXIMA's Avatar
What now?
you still under warranty? If you are take it in or if not call up a dealer and see if they can tell you anything..
Old May 11, 2012 | 09:21 AM
gofastgt's Avatar
It is actually, I'm just lazy and would rather fix it myself if I could...
Guess I'll have to give them a call.
P.S. I graduated PSU in 04. WE ARE!!
P.P.S. No, I didn't know Sandusky lol
Old May 11, 2012 | 07:33 PM
Yeah might as well just to make sure alls good o nice to meet a fellow PSU grad I graduated in 09 where you at these days
Old May 12, 2012 | 11:54 AM
IFuXwiTuZ's Avatar
try to increase the fuse to a higher amp by +5amps or maybe a connection got loose under the center console it only take 4 bolts to remove it 2 on each side
Old May 13, 2012 | 03:17 PM
gofastgt's Avatar
I moved down to Florida for my internship, stayed there for 6 years and now I'm half way back in North Carolina. How about you?
Good tip with the fuse, I'll have to give that a try, thanks so much!
tsi6001
Oct 3, 2022 10:23 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
vybz05
Dec 10, 2015 07:38 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
kjm900r
Aug 5, 2015 07:14 AM
