functional hood scoops?
Old Aug 22, 2012 | 08:56 AM
bgchz56's Avatar
Based on a convo i'm having right now.. Does anyone know the exact process for hood scoops for our max??
Old Aug 22, 2012 | 10:08 AM
dr_2010SV's Avatar
The answer to that question depends on what functionallity if any the hood scoop(s) would provide your car.
Do you want cold air provided to a custom intake system?
(the max has a stock cold air intake)
..or would you want the scoop to allow the excessive under hood heat a way out?
..or you can just slap a couple of non-functional scoops on to look good.
Old Aug 22, 2012 | 01:27 PM
IFuXwiTuZ's Avatar
i think this is a good idea if it could ram air from the outside to the intake (aftermarket) considering its a shorter run then a true cold air it would be much more effective ...but if i was you i would SCRAP this idea and make a custom 4inch with 4->3 inch coupler it gives you 10whp on top of what a TRUE cold air gives you. so thats almost 20whp MORE
Old Aug 22, 2012 | 07:37 PM
dr_2010SV's Avatar
Yep, short and seal it to the underside hood and no leak/rain...BAM. The other part of the problem is the chronic under hood heat....?
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
leatherneck
Sep 30, 2015 09:16 PM
