cvt trans cooler.
Old Sep 7, 2012 | 04:38 AM
1fast4dsc's Avatar
cvt trans cooler.
do they make any real after market transmission coolers for the 7th gens. I've seen a couple online but i don't know if they're legit. car keeps going into limp mode after a couple of hard pulls, smfhh.
Old Sep 7, 2012 | 05:39 AM
MAXAQUA's Avatar
Slow down..
Old Sep 7, 2012 | 06:07 AM
GM_Traitor3.5VQ's Avatar
Pretty much any fluid cooler will work. Check out B&M, but you'll have to buy a parts kit for install.
Or you can just buy a kit made for a G35/370Z and retrofit it yourself. The only real difference is going to be the amount of hose you need to route, which is cheap to buy.
Old Sep 7, 2012 | 07:13 AM
dr_2010SV's Avatar
Seems to me some additional CVT fluid would also be required?
Old Sep 7, 2012 | 09:09 AM
naijaboy's Avatar
^Yep.
Less than a quart.
Old Sep 7, 2012 | 01:47 PM
silberma's Avatar
I looked into the front of the car through the bottom and the grill and it has a small finned cooler in front bottom of the radiator. Would this be a transmission cooler? The owner's amnual does not mention this item.
Old Sep 7, 2012 | 02:59 PM
CorollaULEV's Avatar
Negative. That is the power steering fluid cooler. Transmission cooler is built into radiator like most other traditional automatics.
Old Mar 2, 2017 | 01:29 PM
Darin Helcher's Avatar
Has anyone found a good one that works?
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
jfl330
Sep 4, 2015 01:44 PM
