G37s Rim Fitment Issues
Old Sep 28, 2012 | 08:29 PM
Ceelos86's Avatar
Exclamation G37s Rim Fitment Issues
Hey guys,
I am trying to put on 2011 G37s rims on my 2011 Maxima and I am having fitment issues with the front 19x8.5's.
Do I need to buy 2 more 19x9's? The rear seem to fit perfectly fine. The hubs in the front are virtually matching up which I'm assuming is the issue.
Can you someone please provide me with a solution. I am not sure if hubcentric rings, or spacers, or anything would help me at this point.
Any information would be greatly appreciated!! Thanks!!
Old Sep 28, 2012 | 11:25 PM
Timmy's Avatar
Originally Posted by Ceelos86
Hey guys,
im not much help but whats the issue? they dont fit on your breaks or something?
Old Sep 29, 2012 | 12:46 AM
20_Maxima_10's Avatar
Yeah dude. Ur post is very vague. Whats not fittin? What is hitting or rubbing?
Old Sep 29, 2012 | 01:04 AM
esco115's Avatar
OP, I havent met anyone that has had any "fitment" issues with G37 rims on Maximas... 19x8.5's should work just fine, reason I say this is because usually 19's are on sport pkg models so the rims are made aggressive to clear brembo calipers in case its optioned w/ it. Check and recheck and see whats hitting, or what you arent doing right.
Old Sep 29, 2012 | 06:09 AM
Ghozt's Avatar
not sure what the issue you're having is, can you go more into detail? ive seen pics of Maximas rockin the G37 Rays so its definitely possible.
Old Sep 29, 2012 | 09:03 AM
Ceelos86's Avatar
Sorry for the general issue.. Below is a pic of the rear fitment, which is perfectly fine
Now this is the problem of the Front. It appears as if I need to bore out the rim in order to get it to fit. I am assuming that any Maxima's that you have G37s rims on them have 19x9's all around.
Old Sep 29, 2012 | 09:04 AM
Ceelos86's Avatar
I posted a pic guys.. Let me know.. I called a local shop and they told me that I need 19x9's all around, but I honestly think spacers will fix the issue in the front.
Old Sep 29, 2012 | 09:06 AM
Do the axle splines poke on 7th gens? Maybe they're hitting the center caps and not allowing the wheels to sit flush.
Old Sep 29, 2012 | 11:08 AM
BBmaxi's Avatar
looks like the wheel is not centering ? are u using the right lug nuts ? what is the seat style on the g37 wheels ? are they conical seats or ? and your lug nuts? are they conical lug nuts ?
they are not centering, they are waaay off.
Old Oct 5, 2012 | 11:27 AM
Ceelos86's Avatar
Got it guys thanks!! The 19x9's fit way better so I put those in the front.. and got 5mm spacers for the 19x8.5's in the rear
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
0m3nc0w
Sep 11, 2015 05:21 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
