2009 maxima outside temp issues
Old Jan 2, 2013 | 08:37 AM
wwsowell's Avatar
for the past month my 2009 maxima has been telling me it is a consistant -22 degrees outside! any one have issues like this before? it does not fluctuate at all.
Old Jan 2, 2013 | 04:07 PM
lightonthehill's Avatar
wwsowell - Your problem is new here.
Folks here have complained for over four years about the outside thermometer on the 7th gen taking way too long to rise after being moved from an air conditioned garage or cooler area into summer heat. Takes my '09 over five miles to start climbing. Going the other way (warm to cold) does not seem to have a problem.
But I have not seen your problem posted here, and, unless you are in Point Barrow, Alaska, there is no question that something is not working right with your outside thermometer system.
Old Jan 15, 2013 | 10:27 AM
nyram's Avatar
it is a bad sensor. it will also cause the heat to not work correctly. car thinks it is -22 outside and even if heat is on 65 it blows more like 80. either sensor is bad or unplugged. easy fix.
dank4us
34
Jun 10, 2024 03:45 AM
rtirbany
Sep 8, 2015 11:46 AM
09maxshawn11
Aug 14, 2015 10:07 PM
acw
Aug 13, 2015 12:50 AM
laparka66
Aug 6, 2015 09:36 AM
