Difficult to install a Stillen intake?
Old Mar 4, 2013 | 05:04 PM
Andre77's Avatar
Buying a stillen intake, not sure if i should pay to have it installed or i can do it. Any advice?
Old Mar 4, 2013 | 05:12 PM
Ghozt's Avatar
Installation instructions: http://www.stillen.com/prodfiles/402974~inst.pdf
Keep in mind the Stillen intake is one of the few that can throw a CEL on the Maxima cause the MAF is not in the right spot. Stillen sells an adapter kit to help fix this; but most people just go for a different intake like the Injen or R2C.
Old Mar 4, 2013 | 05:18 PM
Andre77's Avatar
I see. Which one do you have and would you recommend it?
Old Mar 4, 2013 | 05:22 PM
Ghozt's Avatar
I have a custom one but I had Injen on my last ride and they use kick-*** Amsoil filters. The R2C is cool cause it comes with a big shroud to try to block heat (does an okay job of it) and a nice filter. In the end they're all just metal tubes with filters on the end.
Old Mar 4, 2013 | 05:27 PM
Andre77's Avatar
Since i already bought the stillen intake, i will have it professionally installed and save myself some headaches.
. Thanks for the heads up.
Old Mar 4, 2013 | 05:39 PM
Ghozt's Avatar
The installation isn't where a screw-up can happen; it just seems to be hit or miss with the design of the intake. That's why Stillen's "fix" is a spacer kit to adjust where the MAF sensor sits. I'd definitely recommend installing yourself, it's a great first project especially to learn a little about the car with.
Old Mar 4, 2013 | 06:20 PM
Rods03Max619's Avatar
Agreed, I say do it yourself also, and save the money, its a pretty straight forward install...GOOD Luck, if you decide to give it a shot...
Old Mar 4, 2013 | 06:35 PM
Serpent's Avatar
Third that. Get your hands dirty--it's a good project. Bond with your car for a bit. Feels good to DIY. If you get caught up we'll help you.
Old Mar 4, 2013 | 06:38 PM
Andre77's Avatar
Unanimous. Installing this baby myself this weekend. Ill let you guys know how I make out.
Thanks for the good vibe.
Old Mar 4, 2013 | 06:41 PM
Serpent's Avatar
Atta boy! You'll enjoy it. If you're on facebook, join the facebook group. That's a good way to get help quickly if you get stuck in the middle of a project--responses will be a bit quicker there. Either way, feel free to ask questions if you need to. Good luck bro!
Old Mar 4, 2013 | 11:29 PM
Staggered357's Avatar
You CAN do it and with this "redesigned" intake, I have yet to throw a code and I have been using for last 7 mos. I was even able to install without removing my strut tower bar. Not difficult at all.
Old Mar 5, 2013 | 08:47 AM
Shipwreck's Avatar
Niice! Just read everything, take your time, and document what you do (just in case you need to go back a step or two).
And remember: pics or it didn't happen!
Old Mar 5, 2013 | 08:58 AM
RAINMANYEH's Avatar
You should be able to do it yourself with little to no problem. I've installed similar intakes on my lat 3 vehicles and helped a couple of buddies. No special tools needed, just time and patience as some MAF sensors don't have screws holding them in, but rather O rings that can be a PITA to get back in.
Like shipwreck pointed out... Pics or it didn't happen.
Maximeltman
Aug 31, 2015 01:01 PM
sonic7
Aug 20, 2015 12:23 PM
cheftoo
Aug 20, 2015 05:17 AM
Team STILLEN
Aug 10, 2015 04:29 PM
