i need help!!!! traction control light stays on whil driving
Mar 14, 2013 | 07:25 AM
Traction control light stays on while driving.could some 1 tell me why or how to fix...
Mar 14, 2013 | 07:55 AM
stupid question, but have you tried turning it off?
Also, are any other lights on? Many times, the traction control light comes on when you have other lights on as well (like a check engine light).
Check for codes.
Mar 14, 2013 | 07:59 AM
top off your brake fluid. there's probably 1000 threads on this
Mar 14, 2013 | 03:11 PM
obviously I pressed the button but it doesn't turn off, stupid answer. also when im driving the e bake light comes on.
Mar 14, 2013 | 03:16 PM
Quote: obviously I pressed the button but it doesn't turn off, stupid answer. also when im driving the e bake light comes on.
until you top off your brake fluid both of these lights are going to come on. good luck.
Mar 14, 2013 | 06:10 PM
i had the same problem ghozt is right i topped off my brake fluid, problem solved
Mar 14, 2013 | 06:28 PM
Quote: i had the same problem ghozt is right i topped off my brake fluid, problem solved
What's going on with the brake fluid, where is it going. I have been driving 27 years and never added brake fluid to a car
Mar 14, 2013 | 07:03 PM
Ok thanks ghost i will try it and let u know how it goes
Mar 19, 2013 | 04:58 PM
Quote: What's going on with the brake fluid, where is it going. I have been driving 27 years and never added brake fluid to a car
As the pads gradually wear, the hydraulic system has to push the fluid slightly further into the brake lines. Eventually, this begins to take the fluid level in the brake fluid reservoir down to the 'add fluid' line, and the brake alert light and the stability control light both begin to come on, sometimes intermittently, and then steady.
I have been driving since 1949, and at some point, I have had to add brake fluid to every one of my many vehicles. You may have avoided this by having your brakes serviced (at which time, the fluid is automatically topped off), or by having used a service shop for oil changes that routinely tops off all fluids that are not at the 'full' mark.
Mar 24, 2013 | 06:25 AM
i love this forum i was just about to call the dealership about my light then read this >> thanks ghozt and other that posted this fix .checked my brake fluid and it was alittle low topped off and no more light thanks guys!!!!
Mar 25, 2013 | 05:58 AM
This.
Aug 5, 2022 | 06:16 PM
Quote: top off your brake fluid. there's probably 1000 threads on this
I checked my brake fluid and it is full. Any other ideas of why the traction control and abs light are on?
Aug 6, 2022 | 08:34 AM
Brake pads looooooo, fluid push out of reservoir.
if you top off, then, replaced pads, the fluid will seep over reservoir.
checknreplace pads!!
