Shark Fin Removal for Vinyl Wrap
Planning on wrapping my roof with gloss black vinyl but would like to remove the shark fin first so I can get a clean edge as well as wrap the fin itself.
Just wondering if anyone has removed the fin before? I am assuming it is held on with double sided tape but before I start heating and prying on it I'd like to know for sure.
I searched but found nothing on this.
I'll definitely post pics when it's finished
IMO that's a terrible idea. Just start prying? really? How bout spend a little time dropping the head liner? Then if you don't see any bolts or screws then you know its double sided tape. If its bolted and you start prying you could dent the roof/scratch the paint/damage the anntena. Just drop the head liner, hell drop the drivers side or passenger side rear corner and use a flash light to look in for bolts or screws.
I agree and that's exactly what I plan on doing. It probably is double sided tape but I would rather make sure rather than damage anything.
Wow, can't believe I never thought to search for the actual part....duh!!
Looks to me like the cover is not bolted on, just the electronics inside of it, and they are nuts, which means once I remove the cover (either clipped on or taped) I can unbolt and unplug the electronics to remove everything. Then I can remove the left over glue, vinyl wrap the roof and then reinstall everything.
Now I have my answer....thanks so much
Your fingers can pry and give an idea of how it is fastened. Tape gives, bolts dont.
04-16-2020 05:15 AM
RealityCheck
10-02-2015 06:34 PM
Dennis Twohy
10-01-2015 06:01 PM
