Eibach Wheel Spacers and Camber fix
Old Mar 25, 2013 | 06:35 AM
Fundem's Avatar
I was wondering why I havent heard anything here about Eibachs Wheel Spacers. After hearing 2 horror stories from threads about the Ichiba Spacers this weekend im a little afraid of them. How come nobody has mentioned Eibachs, is there a problem with them? Any one own them that can give a little input? Also there camber kits, why is everyone go with the 350Z?
Also, first time with spacers, whats our bolt pattern etc.
http://www.partsgeek.com/catalog/200...amber_kit.html
http://www.partsgeek.com/catalog/200...el_spacer.html
Old Mar 25, 2013 | 07:56 AM
Richy Rich's Avatar
h&r spacers.
Old Mar 25, 2013 | 09:56 AM
Fundem's Avatar
Originally Posted by Richy Rich
h&r spacers.
What about them?
Old Mar 25, 2013 | 11:23 AM
araffio's Avatar
If you read a little more about the Ichiba spacers you will see that the couple of major issues mentioned were due to improper installation. The spacer nuts must be torqued to 80-85ft/lbs using a torque wrench and not an impact gun.
I installed spacers (20mm front and 25mm rear) a couple weeks ago and pulled my wheels off yesterday to check everything. The nuts were still nice and tight. Haven't felt any vibrations while driving and will check the nuts again in a few weeks to make sure everything is still safe and secure.
I think some guys are shying away from spacers because of the couple horror stories out there, but if installed correctly they are perfectly safe. The 20mm/25mm combo makes for a NICE flush look....
Old Mar 25, 2013 | 11:25 AM
NmexMAX's Avatar
dot dot dot ...
5x4.5"/5x114.3mm
I agree, I'm using spacers on both my vehicles and have yet to have any issues, vibration or otherwise.
Old Mar 25, 2013 | 11:43 AM
Fundem's Avatar
Cool thanks... Is there a reason why people don't really get Eibach spacers? Is it a price issue?
I was kind of looking to go with 15mm/20mm
Old Mar 25, 2013 | 12:11 PM
NmexMAX's Avatar
dot dot dot ...
I have H&R spacers, the V.1 Which come with extended studs and of course the spacer themselves. On my Pathfinder I'm using adapters, which are bolted onto the hub with their own studs and nuts, and then the wheels are bolted to them, kinda like the Ichiba v2.
Have yet to encounter any problems on either set-ups.
The H&R's were 130$ per set, I have a set (2) of 5mm, 10mm and 15mm.
The adapters on the Pathfinder weer 250$ for a set of 4.
Old Mar 25, 2013 | 12:24 PM
araffio's Avatar
For me it was price. Couldn't see spending what Eibach's go for when the Ichiba's are just as good.
Old Mar 25, 2013 | 01:34 PM
Fundem's Avatar
Ok im going to try the Ichibas... There are alot of options that I hear about and see on their site and its confusing the hell out of me since i never used spacers before ... Am I getting V1, V2? whats the difference? I want 15mm/20mm... can someone choose them for me? Id really appreciate it.
http://www.ichibausa.com/SearchResults.asp?Cat=837
Old Mar 25, 2013 | 02:45 PM
araffio's Avatar
Get the V2 hubcentric
Old Mar 25, 2013 | 04:35 PM
Fundem's Avatar
Front and rear?
Old Mar 25, 2013 | 09:57 PM
araffio's Avatar
Front and rear?
Yes
Old Mar 26, 2013 | 06:43 AM
Fundem's Avatar
Awesome, you guys are the best... Thanks
Old Mar 26, 2013 | 11:15 AM
Fundem's Avatar
Is this really what I need to get done????... Remove the brakes? i thought it was just take the wheel off and put it on... Or is this for a different car?
http://www.ichibausa.com/SearchResults.asp?Cat=69
Old Mar 26, 2013 | 11:28 AM
NmexMAX's Avatar
dot dot dot ...
Yup, you'll need to replace the studs, which requires the removal of the brakes.
Old Mar 26, 2013 | 11:39 AM
Fundem's Avatar
im confused because ive been going on youtube to see how easy/hard it is and none say remove the brakes...
Also are these the ones i need? I notice the center bore is 66.2 and on the ichiba site its 66.1
http://www.protuninglab.com/wheel-sp...an-maxima.html
Old Mar 26, 2013 | 11:49 AM
araffio's Avatar
If you're getting V2 spacers then the studs do not get replaced. The spacer bolts to the stock stud and there are new studs on the spacers which the wheel bolts to.
No reason to touch the brakes. This is only necessary if you are replacing the stock studs with longer studs, which is not required with the V2's
Old Mar 26, 2013 | 12:03 PM
Fundem's Avatar
Thats a relief... Ordering now, thanks for all your help everyone.
Old Mar 26, 2013 | 01:28 PM
Richy Rich's Avatar
What about them?
Great quality,
I use them on my 3gen Maxima and 350z for over 6 years. Proper torque specs applied.
Old Mar 26, 2013 | 06:44 PM
Fundem's Avatar
Has anyone used blue loc tight on the spacers? What would you think about that? Would I need to get a new alignment after install?
Old Mar 26, 2013 | 08:49 PM
araffio's Avatar
Yes, loc tite is good.
No need for an alignment. This does not effect camber
Old Mar 27, 2013 | 06:08 AM
Fundem's Avatar
ok good to hear about loc tite, i live off that stuff, lol... whats the grease people rub on the studs before install (youtube)?
Old Mar 27, 2013 | 06:06 PM
Fundem's Avatar
One thing I was just wondering... When the spacers are put on properly, do I have to watch for pot holes more, can I still drive semi-aggressive, taking tight fast turns etc. not that I drive like a **** but if it ever came to having a little fun, do I need to tone it down a bit with spacers?
Old Mar 29, 2013 | 09:47 AM
Fundem's Avatar
Anyone... How do you guys drive with the spacers?
Old Mar 29, 2013 | 10:06 AM
araffio's Avatar
No need to tone it down....I drive my 2012 like I stole it....
Once I install the Eibachs that are sitting in my garage I'll drive it even harder.
You should always watch for pot holes, spacers or not!!!
matts95max
Apr 23, 2025 10:44 AM
Hdnseek
Sep 9, 2015 05:55 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
