Eibach Spring Installation Help!
Old May 3, 2013 | 06:46 AM
wolexity21's Avatar
Hey guys/gals, trusted my instincts and abilities and decided to install my Eibach springs myself with help from my boyz. Got done with rear springs pretty straight forward using the DIY guide from here.
The problem I am having is removing the bolt and nut from the top of the strut bar. It is really a PITA. I borrowed a coil compressor and compressed the OEM springs as tight as possible, but that nut and bolt will not budge. My question is, is there any trick to loosening this bolt or do i have to take this to a shop to have them help me out.
Thanks in advance for any tips.
Old May 3, 2013 | 07:35 AM
dr_2010SV's Avatar
The actual trick is to use an impact driver.
I always try to break it loose before removing it from the car. If that isn't possible you need to get it in a big vise and break it loose (don't remove it completly) BEFORE fully compressing the spring.
You always want the compressor to have some spring compression to prevent serious injury of the spring flying off.
Old May 3, 2013 | 07:42 AM
seesole's Avatar
yup, impact driver did the trick for me, it came right off, I was really surprised! the right tool really does make the job that much easier!
Old May 3, 2013 | 07:51 AM
escblads's Avatar
When it comes to tough nuts and I don't have an impact drill/wrench at hand, I typically go with spraying it with Liquid Wrench™, letting it penetrate for a while, then tapping it along the sides with a hammer then trying to screw it off.
Old May 3, 2013 | 08:33 AM
araffio's Avatar
I used an impact gun as well and it came right off
Old May 3, 2013 | 09:47 AM
Shipwreck's Avatar
x2
Loosen it up while its still mounted, but don't fully remove it until you've got the strut out and compressed the spring. Then you can go at the nut with your wrench holding the strut shaft in place with an Allen wrench.
Old May 3, 2013 | 10:01 AM
Serpent's Avatar
Torch that shiz
Old May 3, 2013 | 10:45 AM
wolexity21's Avatar
LOL at torching it, the frustration of getting that close and not being able to finish does make you wanna torch it
But I think I'll go find me an impact driver. Thank you all for the speedy replies
Old May 4, 2013 | 02:56 PM
Wg2k7's Avatar
Or do what I did and drop the fronts out of the car and take them to some sketchy mechanic and offer up 30-40 bucks to swap springs and them go home and do the rest yourself. No injuries and worth every penny to me
Old May 4, 2013 | 06:01 PM
dr_2010SV's Avatar
What ever it takes....and safety is indeed paramount.
Sketchy mechanics not with my car.
Old May 7, 2013 | 09:03 AM
wolexity21's Avatar
So I ended up compressing the springs and getting the bolt off the top of the strut with a impact wrench. Another problem came up, I could not compress the Eibach springs enough to bolt on the strut top. I was sweating and nervous because my car was on jack stand and it was late on Saturday. I was able to find a shop to put the strut back together for me for $58.
I moved to the other side to pull out the strut, and the dawg on bottom bolt would not budge, I needed a breaker bar. I was just so frustrated at this time, I drove to a shop and they charged me $140 for the passenger side swap.
My advise to anyone planning on doing this mod is this. Make sure you have the right tools, jack, jack stand, power tool, impact tool, a shop grade coil/spring compressor, the autozone rented tool is no good IMO. You need a good buddy too to help. The rears are easy as pie, the fronts are the beast. Like someone said above, you can take out the struts and have a shop swap the springs for about $40 each. If you don't have all of the tools you need, do not DYI this project, it was a PITA for me mainly because of inadequate tools.
But the great thing is that I love the look of the car, and already I noticed less rollover on corners and turn, the car feels better grounded and just look delicious, lol.
Next mod is sway bar and strut bar
Old May 7, 2013 | 09:45 AM
Shipwreck's Avatar
Yup. The front springs were a PITA. My friend and I actually used wood clamps on top of the crappy spring compressors to get them to budge an extra centimeter or two.
So... Congrats! Pics?
Old May 7, 2013 | 02:07 PM
wolexity21's Avatar
im swapping out rims and tires tomorrow then i will wash and post pics
Old May 7, 2013 | 03:25 PM
spnkr2000's Avatar
Another option if you dont have an impact... get a pipe wrench, get the socket that fits the nut. Put the allen key in the center, put the socket over the nut and turn the socket using the pipe wrench. Simple and cheap... although an impact makes life so much easier
Old May 7, 2013 | 04:40 PM
trailer54's Avatar
Awesome. Glad it ended up working out for you! Yes having the right tools makes a world of difference!! In for pics!
Old May 7, 2013 | 06:47 PM
DocHolliday's Avatar
And this is why I will be buying my own impact wrench and compressor soon. Sick of having other people do the work. I want to do it in my garage!
Old May 9, 2013 | 04:39 PM
wolexity21's Avatar
As promised, here are the pics. Treated my boys to some kicking Popeyes before starting installation. ride was quite dirty, can you see the "HIGH" scribbled on the Blax WarHead
Here you see it dropped after the install, worth every Penty and drives so much stickier to the road in twisties.
I threw on the 20 inch American Racing Wheels, they are decently priced for the guy on a budget :-P . Went to go get an alignment and the shop told me the car is well aligned, that i don't need one except if i just feel like paying them extra money for the day. Love my auto shop, free diagnostics and decent charges.
Old May 9, 2013 | 05:23 PM
Shipwreck's Avatar
Those rims look great!
I've actually been dreaming about how our cars would look with the VN427P Shelby wheels. I just love that classic look of those rims!
Old May 9, 2013 | 05:29 PM
dr_2010SV's Avatar
Sweet ride my friend. Love that blue all polished and waxed out.
Old May 9, 2013 | 05:38 PM
wolexity21's Avatar
Its actually black, the photo editing must have placed a hue of blue in there
Old May 9, 2013 | 06:13 PM
dr_2010SV's Avatar
Sorry, I thought it looked blue. Either way the complement still stands.
Old May 9, 2013 | 06:25 PM
dr_2010SV's Avatar
Hey Doc,
Though it still won't fill your tires, I bought an 18V impact driver that does quite well for just occasional home use. It worked great for my spring install and knocks the lug nuts off every time with ease.
Old Apr 17, 2015 | 12:54 PM
Asav's Avatar
Not to bump an old thread but for anyone looking for tools for this job etc, if you go to lowes they have an electric impact wrench made by kobalt for like $150 which is usually on sale for anywhere from $100 to $135 that is a beast. knocks off anything you can throw at it including suspension bolts etc. Best value for a tool i have ever bought!
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
