cxj spacers and bop
Old May 26, 2013 | 06:17 AM
moussadakroub's Avatar
cxj spacers and bop
are they worth it ? do you feel the difference in power ? also thinking about getting a uprev rune after i already have AAM competetion exhuast and 69 series typhoon intake i need my family's opinion lol
Old May 26, 2013 | 07:08 AM
Ghozt's Avatar
the intake spacers are awesome - hands down the best performance part per dollar you can get for this car. the BOPs are highly debated, and even if they work as expected it's only a couple horses so I wouldn't worry about them.
I'd pickup the Stillen UD/lightweight pulley, RL y-pipe and then tune @ Uprev
Old May 26, 2013 | 07:22 AM
i heard a lot about the stillen ud pulley belt always snapping off ? do you no anything about that and also since i have the aam exhaust people tell me the rl y pipe wont "fit" on there
Old May 26, 2013 | 07:25 AM
Ghozt's Avatar
ive never heard of the shorter gates belt snapping... it'd have just as much chance snapping as your OEM belt I'd imagine.
I have the AAM exhaust/RL y-pipe and did the test fitment at AAM's shop. you have to trim .5" off the length and re-weld it - preferably the $300 y-pipe instead of the $1400 exhaust - and it fits perfectly! several other people have already done this as well. DEFINITELY worth it, the two together sound incredible. check out my youtube link in my sig for the AAM exhaust vid with the RL y-pipe and turn on your subs!
Old May 26, 2013 | 07:27 AM
will check it out for sure man ! and is the y pipe a bolt on or involves welding ? just out of curiosity ?
Old May 26, 2013 | 07:31 AM
Ghozt's Avatar
normally it's a direct bolt-on. the length of the RL y-pipe is a little longer than our stock y-pipe, and the AAM exhaust was designed very specifically on a car that was running a stock y-pipe. anyone will tell you the AAM exhaust is a tight fit- it doesn't have a lot of "play" like some of the other cheaper exhausts available. a quick cut/weld of the Y-pipe shouldn't cost more than $50-75 at a reputable exhaust shop.
Old May 26, 2013 | 07:33 AM
thnx alot for the info will be ordering real soon ! and man your max sounds awesome !
Old May 26, 2013 | 12:33 PM
dr_2010SV's Avatar
Right, even when I installed the RL y-pipe to my stock exhaust it took one of my mondo screwdrivers to pry the resonator flange over and onto the y-pipe flange. That in itself indicates the y-pipe length is made too long.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 4, 2015 06:04 PM
Maxboy23
Aug 11, 2015 11:59 AM
