minor Shock/Strut noise?
Old Jun 21, 2013 | 05:46 AM
ronemo's Avatar
I have noticed when my '09 Max hits bumps (ie: manholes, potholes, speed bumps, road cracks, etc) I hear a quick "air sound". Hard to explain but sounds like a "Pfffft".. short a brief from each shock/strut or something.. maybe its the tight suspension and normal.. not sure.. anyone else have this? -Ron
Old Jun 21, 2013 | 05:50 AM
Gfporter1015's Avatar
I have noticed it also, it isn't all the time though. I never thought much about it until now. Twice I have heard a crunch sound, kind of like I am scraping something underneath but I know I am not......
Old Jun 21, 2013 | 06:40 AM
Boslax6123's Avatar
The air noise is coming from the shocks compressing. Completely normal IMO.
GNCMaxima's Avatar
This happened to my 2012 at 7k miles. It was a front sturt recall? dont know if its only for the 12' but just thought I would mention it
Posted from Maxima.org App for Android
Old Jun 21, 2013 | 06:41 AM
Akiyukio's Avatar
I have this as well.
It seems normal enough when you consider how shock absorbers work.
Crunch sound, I have not heard, so I am unsure if this is normal or not.
Old Jun 21, 2013 | 10:41 AM
djfergi's Avatar
I had a noise coming from my passenger front strut. At first I thought it was the ABS self check, but the noise happened everytime i took off and hit any type of bump/dip/imperfection in the road.
Here is what fixed the issue.
I had the following TSB applied: NTB10-020
TSB Info:
2009-2010 MAXIMA; CREAKING/GROANING OR RUBBING
NOISE FROM FRONT STRUT AREA
APPLIED VEHICLES: 2009-2010 Maxima (A35)
APPLIED VINS: 2009 – All
2010 Vehicles built before: 1N4AA(*)AP(*)AC 819147
APPLIED DATES: 2010 Vehicles built before: November 3, 2009
IF YOU CONFIRM
On an Applied Vehicle, a creaking/groaning or rubbing noise can be heard coming from the
front suspension coil spring and strut upper bearing area.
ACTION
Install the tube—SPR TUBE UPPER—listed in the Parts Information section onto both (LH
and RH) front suspension coil springs.
PARTS INFORMATION
DESCRIPTION PART # QUANTITY
SPR TUBE UPPER 55018-ZX00A 2
Nissan Brake Cleaner (or equivalent) (1) As needed (2) (3)
Bitumen Wax 999MP-9G001P As needed (2) (3)
I had the thud / pop noise after ever take off. Once the TSB was applied, I only get the thud / pop noise upon start up (ABS Self Check).
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
