Fuse or Relay for Power Windows?
Old Jun 26, 2013 | 08:28 PM
Visionzwp21's Avatar
Exclamation Fuse or Relay for Power Windows?
My power windows have went completely dead, but I can't seem to find a fuse or relay associated with them. I checked the Service Manual and the regular manual but I couldn't find a page on where the actually fuse or relay is located in either the interior fuse box or the engine compartment fuse box.
I also checked on the inside covers of the fuse boxes but couldn't find one that was for the power windows.
Any help would be appreciated since my window is down and cant come up.
Old Jun 27, 2013 | 04:27 AM
Shipwreck's Avatar
If you look on page 55 of the PWC (power window control) section in the FSM, you'll see on the wiring diagram two 10A fuses at 10 and 7 in the fuse junction box. That could be it...
Old Jun 27, 2013 | 11:01 AM
Thank you for assisting. To test this, I went ahead and pulled the fust from 7 and 10. The Driver Side window still work. What else could it be?
Observation: I noticed that I can also not unlock or lock my doors from the driver side button, BUT the car will lock or unlock all doors automatically when I reach 15 mph or shutoff the car respectively. I can also use the keyfob to unlock and lock doors.
This has me pointing towards the BCM maybe?
Old Jun 27, 2013 | 01:32 PM
Shipwreck's Avatar
So do all the other door controls work? It could be that the drivers side control panel went bad.
Here's another idea that worked for other issues some others had. Disconnect the battery for 10 min and see if that resets the computer. See if it all works then. If not, my guess is as good as yours. Could be the BCM.
Old Jun 28, 2013 | 05:20 AM
Thank you for the tip.
I left the battery unplugged overnight, but it still is dead. Yesterday, it randomly started to stutter again, but I used that time to have the windows rolled up
Old Jun 28, 2013 | 05:32 AM
pdub34's Avatar
The motor is gone!
Old Jun 28, 2013 | 06:01 AM
I would have said the same thing, but the passenger window and rear windows all exhibit the same stuttering at the same time.
If I hold the FR, RR, and RL down or up at the same time, they all will attempt to move, but all will stutter the whole time. Once they reach fully opened or closed (and im still holding the switches) you can hear the switches click until i let go. The moment I add the FL to the mix, the FR, RR, RL will completely stop until FL has been released
FL = Front Left
FR = Front Right
RL = Rear Left
RR = Rear Right
AaronL
Nov 15, 2020 11:52 AM
