Yea, I think you might have to get your own relay and wire it up to get the signal to work, I'm in the same delima on deciding if I want to purchase the power side mirrors or not lol
Quote:
you don't need a relay. just figure out which wire is coming from the blinker module and splice that into your turn signalOriginally Posted by escblads
Quote:
Huh, sounds simple enough, I wasn't sure if any of those wires under the dash carried enough current to power the signal indicators, but then again, they are LED.Originally Posted by Ghozt
Quote:
So dealers can make quick an easy money when someone wants to add a feature [/Conspiracy theory]Originally Posted by Scarab27
How come my harness from my car has the wires???
It doesn't make sense I've checked the wire diagram in a sv and its the same amount of wires and the same colorsOriginally Posted by escblads
Huh, sounds simple enough, I wasn't sure if any of those wires under the dash carried enough current to power the signal indicators, but then again, they are LED.So dealers can make quick an easy money when someone wants to add a feature [/Conspiracy theory]
Last time....a voltage tester is your friend!!!
Quote:
Nice!
My title says S, but I have everything except dual moon roof, auto rear windows and sun shade...it's an 09, then you couldn't get the SV with the roof and Sport package!Originally Posted by Scarab27
Nice!
Quote:
That just goes to show u!!!I think all these cars are pre weird there gotta be a fuse or something that I'm missing for them to work cause the wires are thereOriginally Posted by pdub34
Quote:
The cars are not pre-wired for everything. Nissan uses lots of different wiring harnesses for their electronics. This is why you also can't just go buy the OEM navigation screen and throw it in, everything is different when it comes to the wiring. Same reason why you can't just add paddle shifters. Go look in the Factory Service Manual at the wiring diagrams between the different trims and you'll see what we mean. Since you've obviously already plugged it in and verified it doesn't work though, you've already discovered this information.Originally Posted by Scarab27
Quote:
Some stuff on them is pre wired..the s doesn't come with fogs but the wiring is there...doesn't make sense I changed my light switch and put fogs on and I now have fogs just like the svOriginally Posted by Ghozt
you have the tools (FSM) you need to look at them now. Find the page that details the side mirrors and figure out what it has that you don't.
Quote:
My 2010 S did not have the wiring for fogs. I had to tap them into the parking lights. I also don't have the tow hook threading/tow hook. There's a lot of things they seem to have removed from the 09-10+ S models.Originally Posted by Scarab27
I have a S model also and I want to install the side mirrors also please keep me posted on whether you get them to work or not.
