12V Plug not working. Help please.
Old Aug 19, 2013 | 09:02 PM
joegrdoyle's Avatar
2012 w/ Premium Package. Both 12V plugs are not working - the one inside the center console under the arm rest and the other inside the small storage compartment just in front of the first plug. I have pulled both fuses and both are in good shape.
I guess my next step is to tear into the console and see what's going on. Could it be possible that one has failed and caused both not to work?
How in the heck do I gain access to them. Can I simply pull up on them and get them out? I cannot find anywhere how to take the center console apart.
Anyone else had this problem and been able to repair?
Old Aug 19, 2013 | 09:47 PM
13Maximasv's Avatar
The power outlet in my console works but the one behind the cup holder has never worked, going in for repair this weekend
Old Aug 19, 2013 | 09:59 PM
escblads's Avatar
Have you taken a multimeter to it to see if it has either a ground or voltage going through it? That would be the quickest way to see what the problem is since the fuses are good.
Old Aug 20, 2013 | 10:35 AM
joegrdoyle's Avatar
Can you please let me know what you find out?
Old Aug 20, 2013 | 10:37 AM
joegrdoyle's Avatar
No voltage. Didn't know if it was one plug causing a problem for both or both are actually bad. I'm assuming the back of the plugs would be a greater chance of causing the problem than the back of the fuse box, however, if both are not working and independent of one another, I didn't know if maybe I should start at the fuse box.
Old Aug 20, 2013 | 11:58 AM
joegrdoyle's Avatar
Do you guys know if I have to tear apart the entire console or if I can just pop the plugs out the felt trays (for lack of a better term) they are in? I want to get to the back of the plugs to see what is going on but didn't know if tearing apart the console was necessary. I have searched all over for information but little exists on the 7th generation.
Old Aug 20, 2013 | 03:48 PM
09Maxima_Sam's Avatar
It's still in warranty I assume. Let the dealership fix it. It's their problem not yours.
Old Aug 20, 2013 | 04:29 PM
13Maximasv's Avatar
My car goes in Saturday, send me a PM just case I forget as I am off work for 2 weeks
Why don't you just let the dealer handle it since it's under warranty ?
Old Aug 22, 2013 | 09:15 AM
Propa Teknique's Avatar
I'm glad to know about this. I"ll be taking mine in. That is really aggravating.
Old Aug 24, 2013 | 11:51 AM
13Maximasv's Avatar
Mine was just a fuse,
Old Aug 30, 2013 | 09:00 AM
+1 mine was a fuse as well. Took it to the dealership yesterday (first oil change) and they fixed that outlet. As soon as they drove the car to the door so I can leave the outlet stopped working again so they replaced it with another fuse. Really quick and there were free snacks!
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
