Couple pics
Old Apr 6, 2015 | 02:48 PM
  #81
Tommy6905's Avatar
Originally Posted by BIGIRISHSTL
I love the chrome wrapped. Wish I could match gunmetal and slate gray on my Max's! Did you do yourself and what did you use?
I used vinyl for the door handles and the trunk, first time ever using it. Pretty easy to form and work with. On the emblem I used plasti dip with a glossifier. I'm actually in love with the rear end how it came out
Old Apr 6, 2015 | 02:54 PM
  #82
Tommy6905's Avatar
And you can, what I did was order a few samples from Amazon like a $1 each, decided on the closest Match and ordered the material. Just Did a quick search on there and saw gloss gunmetal, also taking off the door handles and trunk piece is simple and the small parts are good practice
Old Apr 6, 2015 | 02:58 PM
  #83
Tommy6905's Avatar
Originally Posted by Snapper1978
^^^^ your try hydro dipping? I think I may give it a shot and it is pretty easy and you can do a lot more colors.
ID love to see how that turns out, not many people are familiar with that process. Correct me if I'm wrong, it's a vinyl that's applied alittle differently? And is still reversible? Sorry I know only a little about the process
Old Apr 6, 2015 | 04:47 PM
  #84
BIGIRISHSTL's Avatar
Good stuff tommy and snapper. I'll look. Taking door handles off is not tedious?
Old Apr 6, 2015 | 05:20 PM
  #85
Dudemaine's Avatar
Curious about this, too. I've read write-ups that are very vague with respect to taking the door handles completely off of the car and then others try to follow the steps in the write-up unsuccessfully.
Is there a definitive thread or set of instructions to take the handles off that anyone knows of? I'd love to wrap the handles.
Tommy, as for your trunk strip there, is the underneath part wrapped as well, or is that still chrome? I know it may be tougher because of the slots for the license plate lights...
Old Apr 6, 2015 | 06:47 PM
  #86
Tommy6905's Avatar
Yes it's completely wrapped with holes cut out for the light and trunk button. I'll snap a pic of that tomorrow. As far as the handles, I followed others instructions before and got very frustrated I couldn't get the handles off.
Here's the deal with the handles, open the doors and you'll see a rubber grommet in line with the door handles. Take that off and you'll see a torx screw, not sure of the size I used a flat head that fit in there snug. Grab onto the small part of the handle and start loosening the screw, don't worry the screw will not come out....now here's the key you'll feel the small part start to come loose but probably won't come right out as expected....don't get frustrated....just keep loosening it, don't stop pulling on it, it'll eventually come loose and pull out. Once you get the small part of the handle off, you'll grab the handle and slide towards the back of the car, then pull towards your body, the rear doors will come right out no problem. The front doors require the same step except removing the Philips screw holding the handle to chrome part, then you'll use a flat head or any type of tool you use to pry the chrome from the handle itself. The small part of the handle on the drivers side with the key hole has one clip you use a flat head to push down and the chrome pops off
Old Apr 6, 2015 | 06:52 PM
  #87
Great description on the door handles. I know the trunk will require taking the interior cladding off similar to changing the license plate bulbs?
Old Apr 7, 2015 | 02:40 AM
  #88
Tommy6905's Avatar
Yes remove the trunk liner, then push the clip to release the wire for the trunk release, there's 3 little bolts, I think 5/16, remove those, push the 2 orange clips in with a pair of pliers and the piece chrome piece will come right off, then you'll feed the trunk release wire thru the hole as you pull the grommet.
Old Apr 7, 2015 | 09:22 AM
  #89
Perfect. Now if I could only find the time to do this!
Old Apr 7, 2015 | 09:23 AM
  #90
Prefect. Thanks tommy. Now I just have to find the time to do it!
Old Apr 7, 2015 | 09:58 AM
  #91
Tommy6905's Avatar
Not a problem, any other questions ask away.
Old Apr 7, 2015 | 12:02 PM
  #92
Tommy6905's Avatar
Didn't have my keys to pop the trunk, but you can see its wrapped around with lights cut out etcName:  285A2BC4-C3BD-4E80-B81E-A2A027286B68.jpg
Old Apr 8, 2015 | 06:54 PM
  #93
13maximaluvr's Avatar
Handles
Great look!
Old Apr 9, 2015 | 02:31 AM
  #94
Tommy6905's Avatar
Originally Posted by 13maximaluvr
Great look!
Thank you sir
Old Apr 9, 2015 | 07:15 AM
  #95
Snapper1978's Avatar
You Sir are Santa himself, I wanted to do my handles but was afraid to mess with them, I will be dipping my handles tonight. Thank You
Old Apr 9, 2015 | 07:28 AM
  #96
Tommy6905's Avatar
Haha merry Christmas you welcome
Old Apr 9, 2015 | 06:31 PM
  #97
SVmane24's Avatar
Hey Tommy, how did you get your wheels and grill black, did you use dip and if so was it hard? I also have a white Max and I love the black wheel look thinking about doing it myself.
Old Apr 10, 2015 | 04:05 AM
  #98
Tommy6905's Avatar
I did plasti dip the Wheels the first time around, but noticed over time the matte black just doesn't look as good as day 1 from road depri, brae dust, and other harsh chemicals etc. the second time around I made a big mistake and plasti dipped the wheels but this time used automotive black gloss spray paint over the plasti dip. I gotta say they looked awesome but what I was hoping for was to be able to peel the paint the same as the plasti dip should, however the paint I used over it overpowered the dip making it impossible to remove. I had to use goof off and lots of elbow grease to remove the paint. My advice if you know for sure you want them black for good get them powder coated, if not use the plasti dip and if u want a shine you the glossifier that plasti dip makes.
Easiest way to plasti dip the rims is to take them off the car, clean the wheel very good and go to work spraying about 4-5 even coats about 15-20 mins apart depending on the weather
Old Apr 14, 2015 | 09:18 PM
  #99
jeffrotexas's Avatar
2014 Maxima pic
Well i bought a Black Crimson Metallic 2014 Maxima with the sport package and couldn't wait to do some cosmetic changes to it. I finally got some time and plastidip the grill, handles, back plate and window trim. I just wanted to play around with it and i really like how it came out. I also added a K&N CAI for sound. I will post pics of the car when i first got it with limo tint in the back and then when I plastidip'd the car. Let me know what yall think.
Attached Thumbnails Couple pics-189.jpg   Couple pics-156.jpg   Couple pics-155.jpg   Couple pics-188.jpg
Old Apr 14, 2015 | 09:31 PM
  #100
2014 Maxima pic
Here is my attempt at platidipping the Maxima a few months later. I am going to replastidip the car because of some imperfections. Also need to darken up the headlights.
Attached Thumbnails Couple pics-036.jpg   Couple pics-029.jpg   Couple pics-034.jpg   Couple pics-035.jpg
Old Apr 15, 2015 | 03:22 AM
  #101
Tommy6905's Avatar
Car looks awesome, and you did a great job. Crimson black is also one of my favorites for these cars, nice color choice
Old Apr 15, 2015 | 04:21 PM
  #102
xlimodriver's Avatar
Just bought this 2012 SV Sport yesterday because my wife loved the colour.
She gets pissed off with me when I call it PURPLE.
Old Apr 15, 2015 | 05:23 PM
  #103
1996blackmax's Avatar
That's a nice looking ride!
Old Apr 16, 2015 | 03:02 AM
  #104
My wife likes purple, I prefer grey.
Old Apr 18, 2015 | 10:49 AM
  #105
Tommy6905's Avatar
Officially no more chrome, just got done vinyl wrapping the window trim gloss blackName:  97B8DC32-94BE-40D7-8CE3-E9ECC337EE6C.jpg
Old May 24, 2015 | 11:18 AM
  #106
Tommy6905's Avatar
Don't know how new this product is from duplicolor but it's basically the same as plasti dip. I was debating getting new rims because mine were starting to pit from the salt over the winter. When I was in advance auto I saw this and decided to give it a try. The color is graphite metallic with a clear gloss applied over, let me know what yas think, it's really starting to grow on me Name:  13208C0A-48A9-4866-ADED-17B7BD17BF1D.jpg
Size:  513.1 KBill get some better pics when the sun starts to go down
Old May 24, 2015 | 07:42 PM
  #107
MaximaDrvr's Avatar
Did you remove the window trim or spray it while in the car?
Old May 25, 2015 | 05:46 AM
  #108
Tommy6905's Avatar
I did neither, I wrapped it with vinyl
Old May 25, 2015 | 07:24 AM
  #109
Dudemaine's Avatar
Nice work, Tommy. Your ride looks great!
Old May 25, 2015 | 08:34 AM
  #110
MaximaDrvr's Avatar
Did you remove the trim to wrap it then?
Old May 25, 2015 | 10:32 AM
  #111
Tommy6905's Avatar
Thanks dudemaine, trying to keep up with you
Old May 25, 2015 | 10:35 AM
  #112
Tommy6905's Avatar
No need to remove the trim, wipe it down good with alcohol and wrap the trim. Can't really explain how to vinyl wrap, YouTube it, There is a ton of videos on how to wrap
Old May 25, 2015 | 11:29 AM
  #113
Plan on doing that next!
Old May 26, 2015 | 09:37 AM
  #114
dexcool's Avatar
Don't know how new this product is from duplicolor but it's basically the same as plasti dip. I was debating getting new rims because mine were starting to pit from the salt over the winter. When I was in advance auto I saw this and decided to give it a try. The color is graphite metallic with a clear gloss applied over, let me know what yas think, it's really starting to grow on me ill get some better pics when the sun starts to go down
Nice touch Tommy. I been considering dipping my wheels as well. Got some gunmetal PlastiDip and Glossifier but now I might have to consider some Graphite Metallic 😉
Old May 26, 2015 | 03:17 PM
  #115
Tommy6905's Avatar
Ya check out duplicolor custom wrap colors, that's what the products called. They have some different colors from plasti dip. Also I've tried the gunmetal from plasti dip before and without the gloss just looks like primer
Old Jun 3, 2015 | 09:33 AM
  #116
Tommy6905's Avatar
Need some opinions
Someone dinged up my drivers door handle and rear passenger door handle good, thank god it wasn't the paint. However the vinyl on the door handles are really dinged up now. So I figured instead of ordering the same color and redoing it. Maybe try
Black carbon fiber? Or
White carbon fiber?
Old Jun 3, 2015 | 10:18 AM
  #117
mikekay's Avatar
Im really interested to see how it holds up on those rims, I heard of guys having little dings and scuffs but nothing even that major.
I think the problem of peeling starts happening once you start to car wash those jets get pretty powerful at times.
Old Jun 3, 2015 | 10:51 AM
  #118
Tommy6905's Avatar
Didn't proof read what I wrote before I hit submit, I'm talking about the door handles, so far the rims are holding up well
***corrections made
Old Jun 3, 2015 | 11:07 AM
  #119
mikekay's Avatar
Yea man that sucks -- Id say if you are happy with the way it did look and plan on keeping the car just paint them the real way, a nice clear coat and they are good to go -- especially if you cant get a nice match.
I look at plastidip as more or less a 'test phase'
Old Jun 3, 2015 | 11:10 AM
  #120
Tommy6905's Avatar
Yes sir I agree, as u can see from when I originally started this thread which was 2 years ago I am very indecisive, it's a good thing products like vinyl and plasti dip exist. Because I get bored very fast
