Maxima will not start :(
Old Nov 20, 2013 | 05:58 AM
Mike Travassos's Avatar
well i tried to start my maxima and it clicks over and nothing the battery is fine ,seems like the starter relay clicks when i press the button but nothing happens no dash lights were on before this happend... what could it be im stumped.
Old Nov 20, 2013 | 06:08 AM
Tommy6905's Avatar
Could be the steering wheel lock issue, just a thought...what year maxima do you have?
https://maxima.org/showthread.php?t=658823
Old Nov 20, 2013 | 06:17 AM
Maxgig's Avatar
Move your selector lever thru the gears then try starting it again. This is a long shot as I wouldn't think the neutral safety switch would be bad this early in the game. (But you never know)
Old Nov 20, 2013 | 07:12 AM
T200's Avatar
Are you sure the battery is fine? I thought mine was too. Check your lights to see if they turn on or press the Start button without depressing the brake to see if the car turns on. If it doesn't then it's the battery.
If it does but still doesn't start, it may be the starter.
Old Nov 20, 2013 | 07:40 AM
its not something i would i thought of at all its now started.
Old Nov 20, 2013 | 07:52 AM
still cant believe that would prevent the car from starting learned something new today.
Old Nov 20, 2013 | 08:40 AM
NCSUpilot's Avatar
Are you on the OEM battery? If so, there have been numerous problems with these. I would recommend having it tested out.
Old Nov 20, 2013 | 09:00 AM
Tommy6905's Avatar
Car wouldn't start one day for me, filled the terminals with distilled water and it started right up. Good thing I wasn't stranded somewhere, good to see its started
Old Nov 20, 2013 | 09:27 AM
Ghozt's Avatar
he figured it out, was one of his halo relays somehow once he disconnected that it started right up
Old Nov 20, 2013 | 10:18 AM
dr_2010SV's Avatar
It's something in the E system that detected the short and kept the car from running/torching the vehicle.
Old Nov 20, 2013 | 01:56 PM
13Maximasv's Avatar
Boston Accent ?
Old Nov 20, 2013 | 05:03 PM
Jig9798's Avatar
Wow ... good lookin out! Awesome that you figured it out. Prolly would've taken a lot longer if you didn't have the auto start.
Old Nov 21, 2013 | 06:46 AM
all is well got it running.
Old Nov 21, 2013 | 12:13 PM
exl_ent_v6's Avatar
check your battery. i got stuck 3 times before it never started again. had to get jumped and the last time couldn't even jump it. ****ing dealer made me get the car towed to the dealership (.5 mile away) they wouldn't allow me to bring them the battery for a replacement unless I paid and couldn't get reimbursed. ****ers.
Old Nov 21, 2013 | 02:54 PM
zoemayne's Avatar
something like that happened to me once. I knew the terminal connection was bad because the aftermarket alarm I had on my car goes off if the battery is disconnected. just tightened it up. good job on figuring that out on your own.
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
halfpol
Aug 5, 2015 08:24 PM
dauntlessmax
Aug 5, 2015 10:29 AM
Jcof88
Aug 3, 2015 10:43 PM
