How bad will it be?
Old Jan 19, 2014 | 08:23 AM
jdke's Avatar
How bad will it be?
I had to have both exhaust valve control magnet retarders for vtc sprockets replaced, bank 1 and bank 2. I was showing codes P0014 and P0024. It was not covered under warranty. The dealership told me Nissan voided the engine warranty on this vehicle when it was turned in from a lease. "excessive engine sludge build up due to lack of maintenance." (bought the Max at auction and this wasn't disclosed). Anyway, that is my issue to deal with and not the point. Two weeks after picking the car up from getting the sensors replaced, both codes are back. I spoke to a mechanic I know and he said this could eventually be a major issue. My SV Max is a 2009, has 34,345k miles. I have had it for almost a year and a half and have changed the oil religiously every 3000K.
What do you guys think is happening, and do you think it is going to be a major problem?
Thanks!
Old Jan 19, 2014 | 08:56 AM
Ghozt's Avatar
I don't know if it this would help at this point, but have you looked into seafoam treatments? Seafoam is supposed to help remote oil deposits and other build up. I used it once around 40k after I had an episode where my car overheated and I wanted to make sure the motor was clean, it put off a ton of smoke it was crazy.
http://seafoamsales.com/sea-foam-motor-treatment/
Old Jan 19, 2014 | 09:55 AM
jdke's Avatar
I will look into that. I was going to flush the engine anyway. Maybe the sea foam works much better. Thanks for the link!
Old Jan 19, 2014 | 02:57 PM
shook187's Avatar
I don't have much to add to this but out of curiosity when buying a vehicle on auction don't you do a CARFAX report before bidding or do they not disclose the VIN number?
Old Jan 19, 2014 | 07:25 PM
jdke's Avatar
Yes you could run the vin and get a car fax report as long as you have enough time when you see the car.
chisam14
Nov 6, 2018 08:56 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
