Braking distance
Old Feb 1, 2014 | 08:17 PM
stealthmaxDFW's Avatar
Thumbs down Braking distance
Does anyone feel the braking distance on the Max is a little excessive along with the ABS being too sensitive? Is this a tire issue or are the stock rotors and pads sub-par?
Old Feb 1, 2014 | 08:38 PM
koreanthunda's Avatar
My 11 sv stops on a dime with no fading
Old Feb 1, 2014 | 09:18 PM
aackshun's Avatar
The real question is, where, how and why are you testing this?
And the even better question... What are you going to do about it
Old Feb 1, 2014 | 11:35 PM
trailer54's Avatar
I think the brakes are great for this size/weight of a car. But anything can always be improved, I've upgraded to Hawk HPS pad with drilled/slotted rotors. Stops great!
Old Feb 2, 2014 | 01:30 PM
dr_2010SV's Avatar
I agree that under normal driving circumstances the stock brakes perform very good.
They will also experience fade under repetitive hard braking like at the track.
Old Feb 2, 2014 | 02:39 PM
I'm comparing the stopping distance and ABS intervention to my former daily driver, a 2006 Jaguar XJ8 on 255 40 19 Bridgestone three-season tires and the same size rotors. It weighs an extra 200 lbs. The ABS on the Jag rarely activates whereas the Max driven on the same roads does. Also, there have been a few stops that did not instill the same confidence as the Jag. The Max almost feels nervous on sudden stops. I think the stock tires might have a lot to do with this.
Old Feb 2, 2014 | 05:18 PM
Staggered357's Avatar
upgrade to the 370z Akebono BBK, and I can truly say that my Max stops on a "nickel".. much better feel more confident and looks absolutely stunning. Direct Bolt on..
Old Feb 2, 2014 | 05:57 PM
aackshun's Avatar
For future reference.... A Nickel is bigger than a Dime......
Old Feb 3, 2014 | 12:12 AM
lightonthehill's Avatar
My '09 Max is over 5 years old, has original tires, brakes, alignment, and not only stops quicker than my previous Maximas (all gens 2nd thru 7th), but is the first vehicle I have driven in 65 years of driving in which every stop is admirably short and buttery smooth, with no sign of pulling to one side or the other, and no sign of vibration or warping or glazing of rotors.
I feel very lucky, as I know some here driving Maximas just like mine have not been as fortunate with their brakes.
Old Feb 3, 2014 | 05:50 PM
That's a sweet brake setup Staggered357. Thanks for the recommendation.
Old Feb 3, 2014 | 05:57 PM
Mike11SV's Avatar
MMmmmm,So calipers bolt up. Do we have to change rotors too?
Will it clear OEM 19"s with no need for a spacer?
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
