HID question for the hid gurus...
Old Feb 15, 2014 | 07:04 PM
bigmike8771's Avatar
i recently purchased a 2011 SV with tech pkg.. i want to put hids in the headlights as well as the fogs. i wanted to see if anyone could give me some feedback on these particular kits here:
http://hidnation.com/kresults.html?y...&e=w/Composite
ALSO, do i need the canceller, or relay??? if so what do they do???
thanks....
Old Feb 15, 2014 | 07:42 PM
ac max 92's Avatar
I haven't used that peticular make but at that price it doesn't look like you have much to lose if you want to give it a go. Im sure they would still last longer than your average halogen which would cost you about that anyway. So go ahead and give em a shot. Just make sure you get the the harness with the relay and inline fuse. The relay will help because without it you put heavy load on the battery and it's piece of mind so your not having any issues with flickering lights.
Old Feb 15, 2014 | 11:30 PM
Grego214's Avatar
TheRetrofitSource.com. Get the H11 kit it comes with a relay. Buy quality products so later down the road you won't have problems.
Old Feb 16, 2014 | 11:31 AM
1gt2nv's Avatar
Get the XB35 bulbs. Or you will have the ground wire shadow.
Old Feb 16, 2014 | 02:15 PM
http://www.theretrofitsource.com/hid...ystem-h11.html
Comes with everything you need. Select the XB35 option (additional $20) so that you don't have return wire shadow in your output.
Old Feb 16, 2014 | 02:19 PM
Ghozt's Avatar
How are the XB35 bulbs compared to the 3Five series? I got the 3Fives currently but been looking at the XB35's. Strangely, both say they're "not compatible with OEM Nissan Matsu****a ballasts" yet I've had no problem.
Old Feb 16, 2014 | 03:40 PM
WiSeGuY187's Avatar
No bc of the fact that the oem ballasts have issues firing aftermarket bulbs
Old Feb 16, 2014 | 03:49 PM
Ross2893's Avatar
When I converted my fogs to HIDs I ended up doing a complete 5000K. I went with Maxlux for the D2S Bulbs as well as there H11 kit for my fogs. The bulbs come with 2 year warranty and the HID ballast come with 3 years warranty. The good thing is that the ballast came with a canceler built in as well as a relay and it only cost $67 for the HID kit and $30 for the bulbs. Been running this setup since September without a single problem
Old Feb 16, 2014 | 04:18 PM
dr_2010SV's Avatar
Please post-up some pic's of what these look like....I'm also leaning towards the 5000K's.
Old Feb 16, 2014 | 04:25 PM
Ross2893's Avatar
No problem, I have a pic right after the install. They look yellowish in pictures but in person they are completely white. I am new to this forum so excuse me but how exactly do you post/attach pictures to a post?
Old Feb 16, 2014 | 04:43 PM
Ross2893's Avatar
Nvm. I figured it out. The pic on top is right after the install and the pic on the bottom is about 30 minutes later when the sun had already set. Again it is pure white in person but in pics it always comes out with a yellowish tint.
Old Feb 17, 2014 | 08:16 AM
Both 3Fives and XB35s are fine with OEM ballasts. In the past, people have had issues with their OEM ballasts being finicky and not firing aftermarket bulbs on the first strike.
XB35s are better quality and have the return wires placed in the right spot so that there is no affect on the output. I'd definitely go with them over 3Fives in any sort of application.
Old Feb 17, 2014 | 11:42 AM
dr_2010SV's Avatar
Very nice...and bright!
Old Feb 17, 2014 | 03:17 PM
Ross2893's Avatar
Yeah thanks. But I've never had a problem with this kit so as of now I can swear by them.
Old Feb 18, 2014 | 02:34 PM
Dudemaine's Avatar
Getting the D2S: Morimoto XB35 HID bulbs in 5000k on 3/1 and will give feedback after installation and a few uses
Any suggestion for the fogs?
I'm on the fence if I want a stronger yellow output bulb or if I want to match the fogs to the XB35's so it's white on top and white on bottom
Old Feb 18, 2014 | 03:44 PM
dr_2010SV's Avatar
I'm going to do exactly what your doing for the low beams. For the fogs I think I'll go with the H11: Morimoto Elite HID System 5000K and the 3five DSP option. I don't need the fogs competing with the XB35's.
Old Mar 14, 2014 | 10:59 PM
webpagesby22's Avatar
I ordered the kit. Did you change the fuses. Which fuse did you change.
Old Mar 15, 2014 | 03:51 AM
Racerbox77's Avatar
I don't think my Maxlux 5k fogs came with relays? I know I didn't wire them in. Mine cost the same wonder why I didn't get relays with them? I'm having issues with mine. The drivers side doesn't light sometimes. About 50% of the time I have to turn the car off and on or sometimes toggle the fogs a few times to get them on. I've left 2 emails for Maxlux and no response as of yet. Can't find a phone # for them that's in America so not sure what's going on.
I was very happy with the quality of parts and especially the brightness but not anymore...
Old Mar 15, 2014 | 07:34 AM
Ross2893's Avatar
I'm really sorry to hear but yes you're right, that was a mistype. It does not come with the relay. I really don't know what seems to be the problem with yours (whether it's defective or not). I've been running this kit since September and the only time the misfired was when they fell off the adhesive pad and kept shaking around. Once I got them zip tied up they have never misfired again. You should try filing a claim through Amazon because you have up to 90 days and since Maxlux did not reply to your emails you would have a case
Old Mar 17, 2014 | 08:28 AM
Funny. My drivers side light went out. I contacted Maxlux from the Amazon website and they have been responding pretty quickly. They are getting me out a replacement ballast asap. Contact them via amazon.
Old Mar 17, 2014 | 09:06 AM
Racerbox77's Avatar
Sent a message through Amazon.com to Maxlux. If I don't hear back by tomorrow I'll file a claim through Amazon.
Old Mar 17, 2014 | 06:58 PM
Racerbox77's Avatar
Maxlux emailed saying to take a picture of the bad ballast after I cut the main wires (proving it won't work again) and they'll ship me a new one. Pretty good idea to stop fraud and not have to pay for return shipping.
Old Mar 17, 2014 | 08:08 PM
I guess it must have been alot of fraud. But i sent my photos and my new ballast is on the way. I will also got to autozone to get another 20 fuse because i only got one in the package
Old Mar 17, 2014 | 08:15 PM
Ghozt's Avatar
Yeah because of that most places require a deposit to send out the replacement item.
Old Mar 17, 2014 | 10:01 PM
Ross2893's Avatar
Again sorry you were having problems with this kit but at least the problem is getting resolved. Just sucks that you'll be one ballast short until then.
Old Mar 18, 2014 | 03:44 AM
Racerbox77's Avatar
Why do you need another fuse?
Old Mar 19, 2014 | 07:48 PM
For the left and right headlight
Old Mar 20, 2014 | 04:55 AM
Racerbox77's Avatar
I may be wrong but isn't there only 1 fuse for the fog lights? I know my Maxlux kit came with a 20A fuse but I figured it was for cars that didn't already have fogs.
Webpagesby, if your one fog is working your fuse must be fine. Again I could be wrong here...
Old Mar 20, 2014 | 08:24 AM
Ross2893's Avatar
The fuse Maxlux provides you is to upgrade your 15A stock fuse to 20A because even though the ballast uses less electricity overall compared to a halogen bulb the initial electrical draw is still greater. If you keep the 15A stock in vs the 20A they provide, you have more chance of blowing your fog light fuse on start up (when running a retrofit HID ballast). Hopefully that made sense without being too confusing
Old Mar 20, 2014 | 03:13 PM
Sorry, I don't have fogs. Its for the Left and Right Lo beam light in my case
Old Mar 20, 2014 | 05:03 PM
Ross2893's Avatar
Ahh yes, that makes sense but I'm guessing the same concept would apply. Real sorry to hear that others had problems with this kit because I have been really happy with both this kit and the DS2 bulbs from Maxlux.
Old Mar 25, 2014 | 03:54 PM
Racerbox77's Avatar
Maxlux sent me a replacement ballast. So far so good!
Old Mar 25, 2014 | 06:05 PM
Ross2893's Avatar
good! hopefully it was just a defective unit.
Old Mar 26, 2014 | 06:04 AM
Racerbox77's Avatar
Unreal. This morning my other fog didn't come on. Had to turn lights off then on and it came on.??
Old Mar 26, 2014 | 08:04 AM
Ross2893's Avatar
Did you replace the fuse from the stock 15A to the upgraded 20A?
Old Mar 26, 2014 | 08:34 AM
Racerbox77's Avatar
No why would I do that? If it's not popping it there's no reason for it. Am I wrong?
Old Mar 26, 2014 | 09:09 AM
Ross2893's Avatar
Fair enough. But Just to eliminate any reason for doubt I guess. I say this because I followed the instructions to a tee and have no experienced the issues you are having so I cannot see why these problems are coming up since it's the same product on the same platform car
Old Mar 26, 2014 | 03:17 PM
Racerbox77's Avatar
I replaced the fuse. We'll see how it goes. Maybe the 15amp won't allow enough power to go through for the initial start up. Hope you're right Ross. Thx
Old Mar 26, 2014 | 05:58 PM
Ross2893's Avatar
That should help. How all goes well
Old Mar 28, 2014 | 04:47 PM
Received my replacement ballast so far so good. I also replaced the fuses with 20a fuses.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
