so can anyone fill me in on the latest in lighting trends ?
these led's seem pretty cool since they are low wattage and does not require
a separate ballast.
http://www.ebay.com/itm/2x-Nissan-Scion-Toyota-H11-White-6-LED-30w-Projector-Low-Beam-Fog-Light-Bulbs-/301099644284?pt=Motors_Car_Truck_Parts_Accessories&hash=item461aeff57c&vxp=mtr
a separate ballast.
No one uses Halogens or HIDs, LEDs anymore, we all use LASERS.
http://wot.motortrend.com/bmw-shows-...rk-126103.html
Back on topic:
There is no way those would be safe of even bright enough to be used as a real headlamp.
Those LEDs are incorrectly placed to be properly focused by the projector.
Also, the green circuit board? Even if they did output a full 30 watts, the heat generated would fry the LEDs in short time as there is no proper cooling solution to ensure heat removal.
Lastly the reflectors surrounding the LED is no way shiny enough or cut well enough (I see rough edges) to be able to direct the light properly and again, help with heat dissipation
Now, there are cars out there with OEM LED lights, however those are properly cooled, aimed/focused, and definitely higher output than this.
If you want to try retrofitting those in, I would love to see the results.
Back on topic:
Nope. Some of the newer headlights have LED projectors, which are completely different, and are more comparable with halogens in terms of light output.
what about these ? the seller claims it's for lowbeam usage
http://www.ebay.com/itm/2x-Ford-Honda-Lexus-Cree-H11-White-10-LED-50w-Projector-Low-Beam-Fog-Lights-Bulb-/390777090155?pt=Motors_Car_Truck_Parts_Accessories&hash=item5afc21306b&vxp=mtr
Long story short, the optics for projectors (halogen or HID) are designed around the source of light coming from a specific single point. LED bulbs like that will not provide any meaningful results since the source comes from multiple points which will not reflect correctly inside of the projector bowl. They would be better served in a reflector application like the fogs or High beams.
Quote:
2X Ford Honda Lexus CREE H11 White 10 LED 50W Projector Low Beam Fog Lights Bulb | eBay
You.... Should not believe everything on the Internet... Especially Ebay...Originally Posted by BBmaxi
what about these ? the seller claims it's for lowbeam usage2X Ford Honda Lexus CREE H11 White 10 LED 50W Projector Low Beam Fog Lights Bulb | eBay
(Are you trolling...?)
I wouldn't even use those bulbs to light up the inside of my fridge.
They will be useless in any application unless you just want to install them for looks/color but you can get a HID kit for that.
If you absolutely want LEDs for your low beams then grab these.
http://www.vleds.com/bulb-type/headl...11-5k-cxa.html
The output won't be as bright as HIDs but they have an alright output.
While those fit the socket of the halogen headlights low beam, I would not use LEDs as a primary source of lighting unless the headlight was designed with the newer LED headlights. This is extremely dangerous guys, don't cheap out and put LEDs in your low beam just do it right.Originally Posted by Grego214
If you absolutely want LEDs for your low beams then grab these.http://www.vleds.com/bulb-type/headl...11-5k-cxa.html
