I iz confused about Offsets
Old Mar 11, 2014 | 05:47 PM
krilla_kurt's Avatar
So can someone explain to me how the offset of rims effects the fit (high offset vs. low offset etc.) in basic terms?
Also I'd like to run this setup Front 19x8.5" +22 Offset Rear 19x9.5" +25 Offset on BBS rims but I want to make sure these low offsets will work?
Input please
Old Mar 11, 2014 | 05:56 PM
dr_2010SV's Avatar
http://www.rimsntires.com/specspro.jsp
Old Mar 11, 2014 | 06:36 PM
So judging by that diagram my offset for the rims I posted will fit but will just stick out farther?
Old Mar 12, 2014 | 05:05 AM
dr_2010SV's Avatar
Right now I'm running 50 offset with 25mm spacers on the front and it's maxed out. So I would say 22mm offset is going to be too much unless someone else has this combo?
The rear should be OK....I'm running 27mm spacers on 50 offsets and there's still a little room but not much.
Old Mar 12, 2014 | 10:39 AM
Jbling700's Avatar
You will be fine. Some one is currently running 20x11 all around with very low offsets.
Old Mar 12, 2014 | 10:44 AM
NmexMAX's Avatar
dot dot dot ...
Depends on your suspension set-up too.
Old Mar 12, 2014 | 11:01 AM
I'm rolling on BC coilovers so I can adjust them easily. I was just worried about the offset, I don't want a crazy amount of rim/tire sticking out.
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
