2013 370Z Wheels Problem
Old Mar 23, 2014 | 05:14 PM
faze2988's Avatar
Hey guys, so I installed a set of 2013 370Z wheels on my 7th gen yesterday. Since the install I notice a very distinct issue. When i hit a bump on the road my car jerks/swerves from left to right 2 or 3 times really fast. It happens on almost any bump. It is bad enough that if i have correct the steering wheel almost every bump..I know for sure it is not a balancing issue because it only happens when i hit bumps..I know alot of members have installed 370z rims on there Maxima. The 2013 Rays are the same specs as the older ones btw and also im running stock 370z tires (245,275) as I rolled my fenders to make the rear fit. I am also on eibach springs and did not have this issue with my previous wheels. Anybody have any input or advice to what this problem could be? Any of you guys with the 370Z rims experience this or is it just me?
Old Mar 23, 2014 | 06:11 PM
Ross2893's Avatar
The problem is the 275 in the rear. Should be 245 all around. Doesn't look as good but it fixes the problem that you're having which I believe is oversteer.
Old Mar 23, 2014 | 07:28 PM
1996blackmax's Avatar
There are several people running a staggered setup, & I've never heard of their cars doing that.
Old Mar 23, 2014 | 07:37 PM
MIA_SHIFT's Avatar
Weird......u check air levels?
Old Mar 23, 2014 | 08:54 PM
Shipwreck's Avatar
My car did that - Alignment shop found it was a toe issue. Might want to check it out.
Also, make sure the tires are mounted correctly, especially if they are directional, and you have them on the correct side of the car.
Old Mar 24, 2014 | 03:10 AM
2011maximapa's Avatar
Reading this has made me realize I may have made a mistake. I just put a staggered set up on my car as well 20 inch 275 in rear 245 up front. I ordered the eibach
Old Mar 24, 2014 | 03:12 AM
Woops hit send by accident. At any rate I ordered the eibach pro kit last night and now reading this do I need to roll the rear fenders to make everything fit? Concerned as I didn't anticipate doing body work.
Can someone please verify this for me so I know what I got myself into?
I'd really appreciate it. Thank you
Old Mar 24, 2014 | 03:24 AM
Racerbox77's Avatar
Sounds like a suspension or an alignment issue. Did you install anything at all besides the wheels? I'd like to see more pics of your Max.
Old Mar 24, 2014 | 04:37 AM
faze2988's Avatar
People have run staggered here without this issue so it cant be the wide tires.....Im going to try an alignment and check my air levels..i didnt think of an alignment because my other stocks wheels didnt do this but maybe the wider wheels made it more noticeable...ill report back asap and will post
More pics later
Old Mar 24, 2014 | 06:14 AM
MEINEKEMAX's Avatar
I have encountered this alot with suvs when we put bigger wheels and tires on. In many cases a good thorough alignment saves the day. I wouldn't be too worried. The staggered set up looks really nice. Well done!
Old Mar 24, 2014 | 06:54 AM
faze2988's Avatar
thanks for the help guys ! An alignment solved the issue. I never got one after installing the eibach springs because it rode fine with the stock wheels. So its a lesson learned wider tires and rims makes a bad alignment 10 times more noticable !!
Old Mar 24, 2014 | 06:59 AM
faze2988's Avatar
what are the specs of the rims? tell me that and i can tell you if you need to roll your fenders
Old Mar 24, 2014 | 07:03 AM
Racerbox77's Avatar
Also tire size.
Old Mar 24, 2014 | 08:14 AM
faze2988's Avatar
Originally Posted by Racerbox77
Also tire size.
He stated it in his previous post...245 front & 275 rear...most likely the rear is a 10-10.5 inch wide rim so in order for it to fit without rolling the fenders the offset has ro be around 40 or higher
Old Mar 24, 2014 | 08:41 AM
nyram's Avatar
alignment
get an alignment done, it will fix it.
Old Mar 24, 2014 | 01:39 PM
Racer box. They are rohana rc10's 20x9 front and 20x10 rear with 245 35 20 on front 275 30 20 on rear and I am unsure of the offset.
Old Mar 24, 2014 | 02:03 PM
Racerbox77's Avatar
Pretty sure will need the rears rolled. Depending on offsets you might want spacers in the front.
And to the OP a 20mm spacer up front will get you flush with 1.5 degrees neg camber. That's what I have
Old Mar 24, 2014 | 02:05 PM
WrightOne86's Avatar
I have those same wheels and tires. The offsets are 35 & 40.
Old Mar 24, 2014 | 05:33 PM
So what exactly does rolling the fenders entail? Sorry I'm new to this
Old Mar 24, 2014 | 06:23 PM
dr_2010SV's Avatar
Usually bending them in for tire clearance but could also include cutting
Old Mar 24, 2014 | 07:08 PM
MIA_SHIFT's Avatar
You shouldn't have to roll fenders to throw the rays on.
Old Mar 24, 2014 | 07:37 PM
dr_2010SV's Avatar
No doubt, but to each his own....myself I'm not a tire stretcher fan.
Old Mar 24, 2014 | 09:35 PM
Eibach pro kit says it only drops car 1.4 inches and there's so much clearance now I'm hoping it just works with no mods. Wish someone did the same thing and could say ya it fits.
Anyways thanks for the feedback and if anyone has any more feedback please offer.
matts95max
Apr 23, 2025 10:44 AM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
