USB and audio jack question
Old May 1, 2014 | 12:01 PM
MikeRS1981's Avatar
Does anyone know if a USB port can accept audio from a 3.5 mm audio jack? Specifically, I want an aftermarket XM radio to connect via USB, and I know they make adapters, but looking for a definite answer if they will work together.
Old May 1, 2014 | 04:54 PM
zoemayne's Avatar
No its not going to play audio directly.
Old May 1, 2014 | 05:11 PM
Nopike's Avatar
A USB port is used to transfer digital information (1's and 0's), The audio from a 3.5 mm audio jack is analog (infinite values). You have to have an adapter to convert the signal from analog to digital. You cannot them connect directly.
The standard USB A plug
Pin 1
VCC (+5 V, red wire)
Pin 2
Data− (white wire)
Pin 3
Data+ (green wire)
Pin 4
Ground (black wire)
If the XM radio has a digital output you may be able to use that with better results.
Fbana41
Aug 29, 2016 12:18 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
homewrecker
Sep 23, 2015 03:41 AM
vrajesh123
Sep 22, 2015 04:20 AM
