Will not unlock/open
Old Jun 20, 2014 | 03:12 PM
eesjunin's Avatar
Key fob or door or inside switches will lock the doors.
Key fob will roll up/down windows.
The car will chirp and blink for both lock and unlock.
But you can't unlock the car neither with key fob, door or inside switches.
The only way in is the physical key.
There is a similar click coming from under the steering wheel.
But when locking you get that locking sound where unlocking does everything it's suppose to just doesn't unlock.
Is there a relay just for unlocking?
Any other thoughts/suggestions?
Thanks!
Old Jun 20, 2014 | 03:25 PM
Amerikaner83's Avatar
have you removed the battery or anything recently?
Old Jun 20, 2014 | 03:40 PM
eesjunin's Avatar
Nope...it was working this morning...parked all day at work..came out to not being able to open the car.
All 4 doors do not unlock
Old Jun 20, 2014 | 03:56 PM
Nopike's Avatar
Not sure what is causing your problem. But I would try another remote and/or change the battery if it's been a while. Try the easy, cheap stuff first.
Old Jun 20, 2014 | 04:19 PM
Shipwreck's Avatar
I've heard some people needing to get the receiver module changed. I've come across this a few times where I couldn't push the button on the door or trunk to open them, but could with the Key Fobb. Really weird.
It might just be that damn "golfball" radar in Pearl Harbor though.
Old Jun 20, 2014 | 04:31 PM
eesjunin's Avatar
^haha nice..
Fuses checked...all good...hmmm
Old Jun 20, 2014 | 05:38 PM
eesjunin's Avatar
So I dug in deeper...found what was clicking when you lock and unlock. It lookalike a slim box that sits horizontally right behind the dashboard. Central control unit? Can someone confirm? The part numbers I am reading are 9E157 or JA03B
Old Jun 20, 2014 | 06:15 PM
eesjunin's Avatar
here are the pcitures of where it is...and the label...anyone can identify this as a Control Lock unit ( or whats the proper name for it?) and out of all the numbers which one is the part number?
Old Jun 21, 2014 | 04:45 AM
Shipwreck's Avatar
I'm pretty sure that's your BCM (Basic Control Module). If it's going bad, Nissan's going to have to replace it. It controls a lot of things like your lights, door locks, power windows, electronic steering column, etc.
Old Jun 21, 2014 | 05:31 AM
eesjunin's Avatar
Thanks Shipwreck!
I took it out this morning.
From another forum, with similar problem, I got it to work intermittently ...by tapping on the relays inside
Which means will have to be replaced and this is only a bandaid.
From what I read , once replaced the keys would have to be reprogrammed to the new module.
I just want to confirm that's true, since it's little tedious to get the module in and out, which I could do. But programming might gave to be done by the dealer .
Old Jun 22, 2014 | 01:46 PM
Shipwreck's Avatar
Nice! Glad you found the issue. Now I hope mine's not going bad >.< lol
Old Jun 22, 2014 | 06:33 PM
dr_2010SV's Avatar
Originally Posted by eesjunin
Thanks Shipwreck!
^Yes, the new BCM (Body Control Unit) will need "write configuration" using CONSULT III.
Old Jun 24, 2014 | 06:10 AM
eesjunin's Avatar
Thanks Doc!
Since...it has been working with no hesitation or missing a beat...not sure why it went haywire that day ...
SO i treated my car, over the weekend, to a bath, barred it and with my new buffer its got a shine on...
Also started to work on some CF'ing....which i will update all in my thread
I am excited as its already loooking sooo good!
Old Jun 24, 2014 | 10:12 AM
dr_2010SV's Avatar
Thanks Doc!
Glad to hear it's working now. But be warned it can and will probably act up again.
Technology is amazing when it works right, frustrating as hell when it doesn't. I had/have an intermittent issues with my door locks as well.
Old Jun 24, 2014 | 10:39 AM
eesjunin's Avatar
I agree!
Well at least i got the picture of the label on that part...which i am still looking around to see which of those numbers is the designated number for the part...and then i can shop around for the part...unlike the steering lock...at least this isnt a crippling "defect"
