Auto Dim
Old Oct 16, 2014 | 05:57 PM
Cdubbs89's Avatar
Auto Dim
Is there a way to keep the auto dim mirror off. It comes on every time I start the car even though i set the memory position to the key while is was off.
Old Oct 16, 2014 | 07:25 PM
WesHild's Avatar
Check your manual.. I do believe one of the buttons on your rear view mirror turns the auto dim off. Dont know which one off hand.
Old Oct 17, 2014 | 03:01 AM
Tommy6905's Avatar
Ya you can turn it off manually every time u get into the car, I think the op is looking for a way to turn it off permanently
Old Oct 17, 2014 | 04:34 AM
Cdubbs89's Avatar
Yes, exactly I want to turn it off permanently.
Old Oct 17, 2014 | 04:59 AM
Daaavid's Avatar
You can either pull the fuse for the [Homelink] mirror or yank the wire out.
On a more serious note, I believe pulling the fuse for it will work but you will lose Homelink functionality if so equipped, or the compass in the mirror.
Old Oct 17, 2014 | 06:30 AM
20_Maxima_10's Avatar
If you're good with electrical, just unplug the mirror and find the 12v ignition switched wire and either cut it or pull the pin and tape it. This will still keep the homelink functions operational due to it being wired to 12v constant, but you still will lose the compass if it's equipped.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
BobTX10
Oct 7, 2015 08:43 AM
dshinn
Sep 26, 2015 08:07 PM
