Headlight help ny 2009 max sv
Old Oct 28, 2014 | 05:04 PM
Villainracing's Avatar
So I have no driverside low beam or both high beams ,
When I turn on switch I get passenger low beam n fog lights work I turn fogs off n still no high beams ,
I changed bulbs and and drivers ballast still no change ,
I also checked fuses under hood all good
Need help thx
Old Oct 28, 2014 | 07:03 PM
Nopike's Avatar
Drivers side low beam (left hand) uses fuse #51 (15 Amp) I would double check that fuse. Even consider swapping it out with another one just to make sure. Other than that it has to be the bulb, ballast or wiring to those. Odd that your hi beams have failed at the same time. Did the problem come out of the blue or was someone working on the car?
The wiring diagram is on page 93 of the EXL section of the FSM. That may help you out.
http://www.nicoclub.com/FSM/Maxima/2014%20Maxima/
I realize you vehicle is a 2009 there should be no difference in the wiring.
Old Oct 29, 2014 | 02:08 PM
Help headlight
Thx I can't seem to find that #51 fuse where is it located
I checked under hood for low n highbeam fuses they are good also chevked the drl fuse it's good too where else can I look and do u know where that #51 fuse can be found thx zgain
Old Oct 29, 2014 | 06:36 PM
Nopike's Avatar
See page PG-64 of the PG section of the FSM I provided to you.
Odd that your hi beams have failed at the same time. Did the problem come out of the blue or was someone working on the car? If someone was working on the car what were they doing?
Old Oct 30, 2014 | 01:54 PM
I did look at fsm link but can't seem to see still where this #51 fuse is
I got the car week ago n didn't look at lights it wAs his daily driver he said it was working idk just can't figure and nissan won't work on it because aftermarket headlight lens
Old Oct 30, 2014 | 02:16 PM
Nopike's Avatar
So somebody worked on the headlights. You need to get a meter to check that you are getting 12VDC to the ballasts. In addition make sure you also have ground going to the bulbs. The wiring diagram is in the first link I provided.
If I had to guess I would bet that a ground wire for the bulbs is not properly connected.
The setup is aftermarket not stock so no telling what might have been done to the wiring. Anyway it should be an easy fix for someone who has the wiring diagram and some knowledge of electrical circuits.
Old Oct 30, 2014 | 02:17 PM
Nitehawk11sv's Avatar
What do you mean aftermarket lense? Have you checked the wiring yet to the fuse box and inside the back projector cover?
Old Oct 30, 2014 | 05:58 PM
I did it's all oem stuff minus a led internal built in strip
Ur probably right bad ground ,I'm trying to have tested tommorow I'm sure now something is loose or not grounded the pass side should be like drivers side matched them up first tommorow the high beams I have no idea I checked all fuse in box by battery all good if there are any other fuses somewhere or relay box I can't seem to find
Old Oct 30, 2014 | 06:07 PM
Nopike's Avatar
The fuses for the hi and low beams are the box near the battery so you probably checked them.
Old Oct 30, 2014 | 06:17 PM
Yea true is there a replaceable relay in the line or something else
Sucks
AaronL
Nov 15, 2020 11:52 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
