BC coilovers installed w/ Swift spring upgrade.
Old Nov 9, 2014 | 06:25 PM
MaximaDrvr's Avatar
I've been doing a lot of work to the car as parts wear out. With 120k miles on the car, and 60k of those on Eibachs, the shocks were blown. It was time to either replace with factory units, or upgrade to coils. After cost comparison, the answer was simple.
I went with the BC coils, Swift spring upgrade, 10k front, 8k rear.
The coils were $995, and the swift upgrade was $320, for $1315 total.
The install was easy and very straight forward. If installed as they arrived, it would have been about 1" lower than the eibachs.
I still need to adjust my ride height and adjust my dampers (next weekend) but am very happy so far. I currently have them adjusted to the same height as I was before the install.
New vs old suspension.
Old Nov 10, 2014 | 02:38 PM
official_style's Avatar
How is the ride? Any clunk noises?
Old Nov 10, 2014 | 04:51 PM
MaximaDrvr's Avatar
The ride is definitely stiffer than before. During rough roads I feel everything. It isn't quantitative, but it feels 'twice' as stiff as eibachs, with my dampers set 1/3 of stiffness setting.
I had a few cluncks as my rear spring cup adapters found where they wanted to sit, and settled in.
I have lowered almost an inch in the rear since the install, just from settling in.
The fronts have dropped about 1/4" since Saturday.
Old Nov 10, 2014 | 05:15 PM
Soooooo �� or ��
Old Nov 10, 2014 | 05:24 PM
1996blackmax's Avatar
In for pics!
You sure have been busy with the upgrades
Old Nov 11, 2014 | 08:53 AM
MaximaDrvr's Avatar
As it sits now:
Old Nov 11, 2014 | 12:38 PM
Are those 20s? Looks awesome bro
Old Nov 11, 2014 | 01:43 PM
MaximaDrvr's Avatar
Yes, 20x9 et30
Old Nov 11, 2014 | 01:51 PM
Yes, 20x9 et30
Any spacers?
Old Nov 11, 2014 | 03:24 PM
MaximaDrvr's Avatar
Another picture.
Nope. And it is just under flush with the fender.
Running 255/35/20.
With eibachs, the tire would rub the fender lip on large bumps...now it doesn't.
Old Nov 11, 2014 | 04:29 PM
Ghozt's Avatar
wish i got the swift springs when i first installed. all i hear is good things about em
Old Nov 12, 2014 | 08:36 AM
lexcitement's Avatar
No Rubbing...
Another picture.
Running 255/35/20.
Hey MD,
No rubbing because of the spring rate you have 10,000(f) and 8000(r)? Thanks...
-Joe
Old Nov 12, 2014 | 09:05 AM
MaximaDrvr's Avatar
I probably wouldn't have rubbed with the standard 7/7 setup.
My old shocks/struts were blown, which led to the rubbing.
Old Nov 13, 2014 | 05:14 AM
09max_sv's Avatar
When I had mine first installed a few days after the rear's settled like yours.
I understand on where you're coming from on bumpy road, oh boy do you ever feel it. lol..
I'm going to order the rear extenders, as it is a ***** getting a hand up the to adjust the setting. My installed left them in the middle, but I think I will adjust them as the same as the fronts (ie six clicks from the middle - to the soft side)
Old Nov 13, 2014 | 09:12 AM
MaximaDrvr's Avatar
Mine are currently four from the middle, towards soft.
Or, 20/32 from full stiff.
Old Jun 20, 2015 | 07:32 AM
Voltaire's Avatar
What would the difference be if the Swift spring specs were the following?
front: 11k
rear: 12k
Old Jun 20, 2015 | 05:37 PM
MaximaDrvr's Avatar
Even stiffer ride.
Would only recommend if you are planning on driving as low as the coils allow, but I doubt it would really be enjoyable. I know one member on here runs 12k front and rear.
Old Jun 20, 2015 | 06:45 PM
maximase86's Avatar
I love lamp.
I have 10k springs (not swift springs though). I think that's too stiff personally. 11-12k starts sounding borderline crazy to me.
Old Jun 20, 2015 | 06:54 PM
Voltaire's Avatar
Even stiffer ride.
That's what I thought. Thank you!
Old Jun 20, 2015 | 07:02 PM
Voltaire's Avatar
Does anyone have pictures of their rear suspension with coilovers? Just curious to see how it looks on a 7th gen.
Old Jun 20, 2015 | 09:09 PM
MaximaDrvr's Avatar
Everything stays in the same place. The shock bodies are height adjustable, and the spring cup perches are height adjustable in the rear control arms.
Old Jun 21, 2015 | 05:00 PM
Voltaire's Avatar
What have you guys done to keep your camber specs in the green with coilovers?
Old Jun 21, 2015 | 05:16 PM
MaximaDrvr's Avatar
Camber bolts in front and the SPC rear camber arms from a 350Z in the rear.
I'm still running at -2 camber because the holes weren't widened in the rear.
I could go to 0 camber, but the toe would be off. Bad toe in will wear a tire a lot faster than a little extra negative camber, and green is -1.8.
Old Aug 19, 2015 | 07:02 AM
Voltaire's Avatar
Where did you order your Swift springs from?
Old Aug 19, 2015 | 09:15 AM
MaximaDrvr's Avatar
It was an optional upgrade from the vendor.
Old Aug 21, 2015 | 12:14 PM
Voltaire's Avatar
Why did you do different spring rates for front and rear (with stiffer springs in the front)? I'm just wondering because I've seen another guy do 11k front and 12k rear (where he made it stiffer for the rear).
Old Aug 21, 2015 | 08:56 PM
MaximaDrvr's Avatar
More weight is up front, so it should have equal to or great strength springs than the rear.
The exception is some true racing applications.
The long hand for the spring rates is kg per mm. So my fronts are 10kg per mm compression. This also works out to 610lbs per inch.
The car is front weight biased and going over bumps is going to load the front suspension more than the rear. Suspension geometry also plays a role in what spring rates are needed. Where a 10k is stiff for me, it is considered a soft spring in the 240/drift scene.
The 'factory' setup is 8k all the way around, but a few people mentioned that they thought the front was too soft for riding low and the rubbed over bumps because of it.
I didn't want to find out how true that was and a 10k spring seemed to fit the bill.
Old Aug 21, 2015 | 10:37 PM
Voltaire's Avatar
Great information. Thank you!
Old Sep 1, 2015 | 01:27 PM
Voltaire's Avatar
After 10 months now, how has the ride of the Swift springs been for you? Would you recommend anything different from the 10k front and 8k rear setup?
Old Sep 1, 2015 | 03:31 PM
MaximaDrvr's Avatar
My wife says it is too stiff, but I think it is great.
I would not do anything differently if I did it again.
It is definitely on the sporty to rougher side when compared with a true commuter car, but I did a 6 hour drive two weeks ago with no complaints.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
