Constant Grinding Noise
Old Nov 26, 2014 | 08:19 AM
LudaTej's Avatar
I have a 2009 model and recently I've been hearing a weird grinding noise coming from the front end. My initial thought was that it's a bad wheel bearing but I wanted to be sure before I buy parts for no reason.
The grinding can be heard at any speed. I also know it's not a tire issue because I jacked the front end of the car up, took the wheels off, and put the car in drive. You can hear the noise even then so I'm convinced it's related to the drive axle.
I attempted to record a video of the grinding noise but my phone barely picked up the sound. I've also searched around on the forum and most people with similar issues ended up having a bad bearing. But I know with bearings the common diagnosis is a high-pitched humming noise. The issue I'm having is more of a low-pitched grinding noise, like something heavy was being dragged across the floor.
Any help would be appreciated. Thanks in advance!
Old Nov 26, 2014 | 08:52 AM
Tommy6905's Avatar
So are u saying the noise can still be heard even when the car is not moving? Maybe I misunderstood
Old Nov 26, 2014 | 09:15 AM
LudaTej's Avatar
Yes the car was jacked up and I put the transmission in drive. The car wasn't moving since it was off the ground but the rotors were spinning.
Old Nov 26, 2014 | 09:23 AM
Tommy6905's Avatar
Oh ok I gotcha now, I'm willing to bet it's a bearing, I had the drivers side replaced recently and compared to other cars I've had in past there was no loud humming, it was more of a grinding sound. I could also feel the vibration thru out the entire car especially the drivers and passenger seat
Old Nov 26, 2014 | 10:36 AM
LudaTej's Avatar
Sounds about like what I'm dealing with. At times I'm able to feel vibration through the gas pedal.
I plan on replacing it myself but I do not have a bearing press. Is it possible on our cars to just buy the entire hub assembly with the bearing already pressed in and replace that. If anyone else can chime in and offer their knowledge it would be appreciated.
Old Nov 26, 2014 | 01:15 PM
Tommy6905's Avatar
I can't speak to if you can buy the whole hub assembly, but vibration in the gas pedal was another symptom I had. I was able to get mine replaced under warranty so I lucked out
Old Nov 27, 2014 | 12:42 AM
ThinBlue82's Avatar
Its your wheel bearing.
Old Nov 27, 2014 | 05:10 AM
koreanthunda's Avatar
I agree the bearing is bad the sound will change one rotating or with a load also .
Old Nov 27, 2014 | 07:46 AM
Nopike's Avatar
Looks like you can just change the entire hub assembly.
http://www.courtesyparts.com/maxima-...8375_8376.html
The FSM would probably be helpful:
http://www.nicoclub.com/archives/nis...e-manuals.html
Old Nov 27, 2014 | 08:49 AM
Way easier to just put in the whole thing
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
