Wrong wheel alignment
I just got a 4 wheel alignment at Firestone. When I got home and looked at the paperwork, I realized that the specifications were for the 05-08 Maxima and not my 2010 Maxima. I called and spoke to the service advisor who told me I can bring it back in and they can put it back on the machine should I choose, but he said that it shouldn't be a problem because the specifications don't change that much. I know that was for the old body Maxima and not mine. The car rides fine and I don't feel any issues. Should I take it back in or just keep it as is unless I feel something? Thanks.
if the steering wheel is centered and it drives straight, dont worry about it
Pretty easy after the first time. I was very happy with the results. Saves a lot of money if you are working on the front suspension on a regular basis.
https://maxima.org/forums/4th-genera...alignment.html
Here is a visual guide.
https://www.youtube.com/watch?v=0sguZ-gRF9I
I expect track width for all 7th Gens is the same. Front and rear were different on the 4th Gens.
Track, front (in.) 62.4
Track, rear (in.) 62.4
http://www.edmunds.com/nissan/maxima...est-specs.html
I'm assuming that just like the 4th Gens, toe is the only thing adjustable on the front end for 7th Gens. Looks like suspension design has not really changed in 20 years. But that is probably true for most cars.
3rd gens i know had IRS, i believe 4th gen and up is when Maxima went to solid rear trailing axle
